08' ranger 3.0 fuel filter replacement "any precautions??"
Old Feb 27, 2010 | 03:40 PM
jammonster's Avatar
jammonster
Hi there ford fanatics, Jammonster here and I could use any advice for changing the fuel filter on my beloved 08 ranger. I looks simon simple, but is it?? It has these cool I'm guessing push in the sides and pull buttons instead of the old school clamps. I don't want to break anything so can someone give the precautions if there are any. I would greatly appreciate and words of wisdom on this. Thanks a bunch!!
Old Feb 27, 2010 | 06:31 PM
Rockledge's Avatar
Rockledge
Make sure the fuel system is de-pressurized first. One way is to pull the fuel pump relay and crank the engine over and let then it die.
Old Feb 28, 2010 | 08:20 AM
03 Maz B23's Avatar
03 Maz B23
To remove fuel line clips press in (and hold pressure) on the large flat spot with a small flat blade screwdriver while moving line toward filter and then pull straight off.
