So I'm finally getting rid of the original battery, and I'm looking at replacing it with an Optima series. The question though is hood height. The documents for it specifically state check for adequate clearance under the hood.
Anybody know if an optima series battery will fit under the hood of a 2000 Ranger 3.0?
What about battery hold-downs? I notice that this battery takes special types.
dont know about your vehicle but I have red tops in my 94 and wifes 01 accord. Use basic hold down aftermarket type, the kind that goes overe the top and is held with 2 j bolts.
Dont get a yellow top as they are only 1 year warranty and the one my son got just barely lasted over a year so no warranty on it.
Really?? I have a buddy who is typically spot on with products and he was raving about them.
I might run this past him - see what he thinks. I'd hate to think a 150 dollar sealed battery is "junk" - especially when compared with normal Sears Diehards at 80 bucks.
Well for what it's worth I did actually get a Motorcraft battery. In the end I made the same decision a lot of you seem to have - the original lasted 10 years, might as well get another.
On a side note: I also had to replace the negative battery cable - the terminal clamp cracked and I suspect accelerated the death of my battery too.
I talked to the dealer and he said the replacement part was considered by Ford to be obsolete - there are only 3 left in the Wisconsin (?) werehouse. So I boogied over to NAPA and their OEM replacement was 67 bucks - I didn't realize the cable was a siamese style. But, I did end up cutting off the clamp, then bolting on a replacement terminal. Not how I would like to have done it - but it was the only way.
