ABS Wheel Speed Sensor
Old Feb 27, 2010 | 08:46 PM
Eaglefixer's Avatar
Eaglefixer
How does the right front sensor come out on my 96 Ranger. I have remove the bolt but can't get it out. Is there a trick so i don't tear it up? I'm in the middle of trying to change my ball joints so any tip there would help alot.
Old Feb 28, 2010 | 05:06 AM
pgw85706's Avatar
pgw85706
After removing the little bolt, it should pull out. But it is a very tight fit and you have to be delicate with it. Try some WD40 or PB blaster to eliminate any corrosion particles first from the ID of the hole. Then try to rotate the sensor back and forth before pulling on it. Again it is a very tight fit and you have to be patient with it.
vronp
Jan 19, 2014 11:29 AM
97ExplorerEB
Jul 26, 2007 08:50 PM
tietje_3
Sep 29, 2006 04:39 PM
geoaigel
Jan 10, 2005 10:50 AM
MustangGT221
Nov 1, 2004 06:43 PM
