Which tool would one need to remove the fuel line fittings from the sending unit, tank selector, pump, etc. on an 86 efi F150? They don't look like spring locks...
The fuel line fittings on 86 efi does n't look like spring locks.. it required just a small screwdriver.Loose the clip up and then pull it out. It may brake so have some new ones on hand.After opening that pull the hose (line) off.
To put the fuel line back on just push the hose on and then push the new clip in.
But he dose need the tools for the fuel rail.
What you are talking about not needing a tool for are the ones on the Tanks, Selector Valve, High Pressure Pump and the Fuel Filter if he has an Fuel Filter on the frame. Some 86 just had the Fuel Filter inside the Selector Valve.
