Backfire and rough running efi 302 needing help
Old Sep 18, 2014 | 11:38 PM
JamesF-250's Avatar
JamesF-250
My 86 ford f250 has the efi 302 and is running rough when in gear and backfires a little. Any ideas why? And could it be something besides timing? Ive retimed it, fuel pressure check, checked the sparkplugs, replaced the fuel pressure regulator and fuel filters and spark plugs wires and coil are just a month old
Old Sep 18, 2014 | 11:40 PM
JamesF-250's Avatar
JamesF-250
Rough in gear i meaning puahing the throttle when its in drive
Old Sep 19, 2014 | 07:27 AM
ctubutis's Avatar
ctubutis
First thing to do when diagnosing a computer-controlled engine is ask the computer what it thinks is going on; here's how:
Ford Fuel Injection » How To Run a Self-Test
Old Sep 19, 2014 | 10:01 AM
reflector's Avatar
reflector
Unhappy f-250 87 - burnt valve on #1
Have you done a compression check?
I've been having similar issues with my '87 f250 302. It runs fine until the engine warms up, then it has an awful misfire, causing it to run really rough under any kind of a load (as soon as it's in gear and you give it gas). I finally gave up chasing possible culprits: egr components, tps, aic, vacuum leak, etc. I broke down and took it to a real mechanic who did a compression check and found #1 down around 120, with the rest in the 180's. Further inspection revealed the burnt valve on cylinder #1.
Hope this helps.
-j
Old Sep 19, 2014 | 01:57 PM
JamesF-250's Avatar
JamesF-250
Ive done a compression test and a fuel rail pressure test and they check out fine
Old Oct 8, 2014 | 10:07 AM
JamesF-250's Avatar
JamesF-250
Finally figured it out. I had a capacitor on my sound system which backfed into the battery casuing a voltage spike which fried my EEC
rlester
Jan 17, 2016 07:01 PM
wildjon300ci
Oct 16, 2006 05:02 PM
RyanMiller
Jan 25, 2005 01:01 PM
RyanMiller
Jan 17, 2005 07:38 PM
irish56
Aug 14, 2002 12:23 PM
