door tag info on 66 short bed 4x4
B: 6cyl 300ci 150HP 3600 RPM 1V
C: Assembly in Ontario, Canada
860404: Born in May of 1966
L: Color Holly Green (Dark Green), Med. Green Woven Plastic and Crush Vinyl
C5: 4.10 gear ratio, limited slip, Dana 60 (3300lb)
A: Transmission NewProcess 435 4sp Manual w/ Granny 1st gear
115: wheelbase (short)
81=A= Standard Cab
DS0= District Code= 34=Indianapolis
5160= special order code
81=A= Standard Cab
L - Medium Green Crush Vinyl & Medium Green Cody Pattern Woven Plastic
81A - Custom Cab
and as my mistake on an earlier decode, 115 wheelbase does not mean short bed, as it could have come with a flat bad, no bed, etc.
but pretty good for a first!
(sigh) If at first you don't succeed, try try again...F11 = F100 4WD
B = 300 1V I-6
C = Oakville Ontario Canada Assembly Plant
860404 = 1966, assembled in May 1966.
115" Wheelbase
L = Holly Green.
F110 = F100 4WD / 5600 lbs. GVWR
381: 3 = Medium Green Crush Vinyl & Medium Green Wicker Pattern Vinyl // 81 = 81A Standard Cab
A = New Process 435 4 Speed Manual Transmission
C5 = Dana 60.2 / 4.10-1 / Limited Slip / 3300 lb. Rear Axle Capacity.
5600 lbs. Gross Vehicle Weight Rating
150 net HP @ 3,600 RPM
345160:
34 = Indianapolis IN Ford District Sales Office, where the original selling dealer ordered the truck from.
5160 = Domestic Special Order number. This truck was a special order, not "bought off the lot."
