Superduty Gears in an Ex???
Old Feb 10, 2010 | 08:18 PM
nghtrgr's Avatar
nghtrgr
Can someone tell me if the gears from a 2003 Ford diesel F350 crewcab dually 4x4 will fit in a 2005 Excursion 4x4??? I looked at a 03/04 at my work and the front axle appears the same, confident there. The rear axle housing on the SD looks to be beefier and a bit different. Are the ring and pinion gears compatible??? There is a set of 4.10's for sale on craigslist for cheap I just don't know if the rear gears are the same with a different housing or just not compatible. Thanks
Old Feb 10, 2010 | 09:55 PM
Digger 5's Avatar
Digger 5
Single rear wheel SD trucks had our Visteon 10.25/10.5 but the DRW trucks had a Dana 80. They will not interchange.
Old Feb 10, 2010 | 10:00 PM
housedad's Avatar
housedad
Sorry, but no, you can't fit a 2003 Ford diesel F350 crewcab dually 4x4 gears into any Ford Excursion. The Excursion has a Dana 50 front axle and a Ford 10.5 rear axle.
The 2003 superduties used dana 60 front axles. The ring and pinion are not interchangeable with a dana 50 that is on the front of the Excursions. However,
The Dana 60 can be pretty much just bolted up to the Excursion. A full axle swap. The rear axle of a Dually is a different story. The 2003 superduty Dually has a Dana 80. Totally different set of gears.
Old Feb 11, 2010 | 05:41 AM
ReAX's Avatar
ReAX
pretty much what he said. gears can be had for decent prices. i prefer motive's performance line, they are as quiet as OE for around half the price. I want to say my front gears cost about $225 and the rears were $300. The install was the expensive part, i paid my local shop (drive line shop) around $900 and it took a day and a half to do them.
Old Feb 11, 2010 | 08:28 AM
howler4x4's Avatar
howler4x4
What they said, plus...
It's really not advisable to install used gears. The ring and pinion take a set together, when installed in a different housing they will take a different set. The result is wear on the tooth faces.
You could 'probably' get away with it on an Ex front, where the gears are idle 95% of the time.
But even that would only make economic sense if self-installed. It would be crazy to pay someone to set them up.
Old Feb 11, 2010 | 10:06 AM
Digger 5's Avatar
Digger 5
This is very true. I rarely recommend using used gears in a rear axle. A REALLY good installer can come very close to matching the original set up but close could still be over .005". Excessive gear wear is very possible with that much pattern change and gear noise is possible. In the front it's not a big deal and it's done very frequently.
Good catch Howler, I should have said this on my first post.
Old Feb 11, 2010 | 10:36 AM
howler4x4's Avatar
howler4x4
Thanks Digger. I didn't see it as left out, but as extra info.
Even more extra...
A part-time front axle like our Dana 50 is a good place to learn diff set up. If the set-up reasonably good it will last because the gears are usually idle, only working in 4WD. So a set-up that would die in 50K miles will last years. Unless you are in Alaska or similar 4WD all-the-time conditions.
This does not apply to AWD, front axles w/o locking hubs, those weird axle shaft discos, t-cases that always spin the front shaft, etc.
Old Feb 11, 2010 | 05:14 PM
nghtrgr's Avatar
nghtrgr
Thanks for education. All good points. Sometimes in the long run cheap isn't cheap.
Old Feb 11, 2010 | 05:36 PM
Vijay's Avatar
Vijay
to be specific my dually is Dana 60 front and Dana 80 rear with 4.10 gears
mjdaye
May 31, 2014 04:49 PM
rustfreemike
Apr 20, 2014 10:20 AM
yzoldowl
Aug 21, 2013 02:00 PM
Mike E.
Sep 27, 2011 08:14 PM
aurgathor
Oct 23, 2004 10:36 AM
