Sponsored by: Real Truck
1999 Rexhall Rexair motorhome v10-start problem
Old Jan 30, 2010 | 08:30 PM
bigsidster's Avatar
bigsidster
Hello---new here and have been reading forum for 4 hours.Got some ideas as to what my problem may be but would like to hear from you experts that have been around for awhile----or lead me to the proper area in the forum.
My problem is that since the weather got cold whan i go to start my v10-6.8 gas powered motorhome it seems like it starts on one cylinder and then dies.It will do this 3 or 4 times and then finally maybe on the 4th or 5th try it will fire up and run fine.When it starts i get a grayish cloud of smoke for a few seconds and then it disperses.(like maybe gas flooding).I let it run say for 5 min and shut it off and then restart and it fires up no problem,and no smoke.
This problem started on thanksgiving weekend and i have not used motorhome since.Since thanksgiving i have cleaned k&n air filter,changed plugs,checked-cleaned and sealed cops,changed oiland filter,changed fuel filter,and added fuel purge to the gas tank.It still has not changed the starting problem.
My reading leads me to think i may have to clean the IAC and MAF and maybe Trottle body and plate.Other then that do you guys have any ideas to help lead an old timer in the right direction?
Old Feb 1, 2010 | 07:23 AM
powerstroke72's Avatar
powerstroke72
Welcome to FTE bigsidster! I can't help you much on the V10 issue but I would encourage you to repost this in the V10 forum here:
Modular V10 (6.8l) - Ford Truck Enthusiasts Forums
Since your problem seems to be more engine specific, you'll likely get more of a response in the V10 forum than in the Super Duty forum.
Best of luck resolving your issue and again, Welcome to FTE!
Old Feb 1, 2010 | 08:13 AM
Monster-4's Avatar
Monster-4
Does it start better of you give it a little throttle while cranking the starter? If so it sounds like the IAC needs cleaned or replaced.
Old Feb 1, 2010 | 08:54 AM
bigsidster's Avatar
bigsidster
1999 6.8l triton motorhome
Pulled and cleaned the IAC-IDLE AIR CONTROLLER--and reinstalled and it runs like a champ.Starts right up now.When I removed it ,it did not look that dirty.It had a fine film of soot in chamber and around the spring and flap seal.I cleaned this with electrical spray cleaner and a rag.Also swabbed out the port.That did the trick.Thanks for all the info on this site.
<!-- / message -->
<!-- controls -->
bismic
Jun 17, 2023 12:54 PM
scottscheffer
20
Aug 16, 2016 05:21 PM
rwallya
New Member Introductions
Oct 23, 2015 01:52 PM
sackedbysapp
Jan 27, 2015 10:23 AM
mredwv
15
Jan 22, 2008 07:38 PM
