4 hi works great, clicks right in. But when i hit 4 low its not engage and im not hearing the relay click in the dash. So is there a common problem with this?
Im assuming either the 4 low button or the relay is bad.
i sould if i knew which terminals to jump, i pulled the switch out thinking it was going to be a simple 2 wires for each switch, found out that it was a 8 wires for 2 switches all together. Had no idea what was what.
