4 Low not working
Jan 12, 2010 | 04:18 PM
4 Low not working
4 hi works great, clicks right in. But when i hit 4 low its not engage and im not hearing the relay click in the dash. So is there a common problem with this?
Im assuming either the 4 low button or the relay is bad.
Jan 12, 2010 | 05:16 PM
Vehicle is stopped with the transmission in neutral when you hit the button right?
Jan 12, 2010 | 06:28 PM
yup. and foot on the brake.
Jan 12, 2010 | 06:50 PM
And with 4 HI already engaged?
Jan 12, 2010 | 07:50 PM
Yup... already in 4 hi , tried neutral, park and with my foot on the brake. no clicking at all
Jan 13, 2010 | 06:46 PM
Jan 18, 2010 | 10:40 AM
Jan 23, 2010 | 06:58 AM
where is the 4x4 low relay located so i can see if im getting power to it?
Jan 23, 2010 | 02:40 PM
okay well anybody know how to take the headlight **** off so i can get to my switches. still dont know where the relays are
Feb 5, 2010 | 05:01 PM
nope no luck. I assume its the relay thats on the passenger side of the truck, but i dont have one to switch with it at this time.
Feb 5, 2010 | 10:01 PM
not sure as mine is older .. non-electric ..
did you try pulling the connector off the switch and jumping the terminals to determine that it is not the switch ..
Feb 6, 2010 | 07:23 AM
i sould if i knew which terminals to jump, i pulled the switch out thinking it was going to be a simple 2 wires for each switch, found out that it was a 8 wires for 2 switches all together. Had no idea what was what.
1990 ,
1999 ,
44 ,
4x4 ,
99 ,
f150 ,
f250 ,
ford ,
hubs ,
inop ,
low ,
manual ,
rims ,
truck ,
trucks ,
working ,
works
