instrument bezel 1996 f150
Old Jan 11, 2010 | 04:37 PM
getwet92's Avatar
getwet92
how do you change the instrument bezel in my 1996 f150 how do you get the **** of the neadlight switch
Old Jan 11, 2010 | 05:02 PM
Virto's Avatar
Virto
There's a little spring clip in the plastic part. Pull the **** all the way out and look down from the top, you should see it. Use a small screwdriver and work it around unless the tension is reduced enough to pull the **** off.
Or use the method I did, and break the ****, then glue it back on. lol
Old Jan 11, 2010 | 05:07 PM
getwet92's Avatar
getwet92
I just found that there is a button on the back side of the switch push it in and the **** and shaft come out
dmejack
Feb 2, 2012 02:04 PM
honeys 29
Nov 24, 2010 01:00 AM
1966_F100
29
Oct 16, 2009 04:55 PM
dbrown13
Jan 31, 2003 04:08 PM
Patrick2002
Oct 14, 2002 05:47 PM
