How can I tell what size ring gear my Expe has?
Old Jan 7, 2010 | 09:04 AM
Junebug_'s Avatar
Junebug_
I think my truck has the larger ring gears in its differentials, but I am not sure. Is there a way to be certain about it?
Old Jan 7, 2010 | 09:43 AM
benningstspeed1.0's Avatar
benningstspeed1.0
WHAT YOU MEAN LARGER RING GEARS. DO YOU MEAN 8.8 OR 9.75. YOU SHOULD HAVE THE 9.75
Old Jan 7, 2010 | 09:45 AM
Junebug_'s Avatar
Junebug_
Right, how can I tell if I have the 9.75?
Old Jan 7, 2010 | 10:45 AM
fordtech08's Avatar
fordtech08
you have a 5.4 so it's a 9.75 rear end however just to make you feel all warm and fuzzy inside crawl under your truck look at the rear end if it looks like an squared circle( a square with rounded corners) then it's an 8.8 however your rear end will be curved on the driver side and have two angled lines going into a veritical line, now thhat you are confused read the tag that is on one of the bolts it says 9.75 it will also say 3L55 for your ratio
Old Jan 7, 2010 | 01:50 PM
Junebug_'s Avatar
Junebug_
Great, Thanks!
Marauder2004
29
May 29, 2016 05:59 AM
fordbroncodave
Nov 19, 2015 09:00 PM
cws10190
Nov 10, 2012 08:01 PM
Drcoolhand
Mar 4, 2012 12:38 PM
TheWhiteBeast
Feb 10, 2011 07:30 AM
