Weird noise and hesitation 5.4L. **Video link**
Old Dec 8, 2009 | 07:18 PM
i eat hybrids's Avatar
i eat hybrids
http://good-times.webshots.com/video...02940326OxPvbg
My F150 has been makin a weird noise for the past two days. The noise only can be heard while idlin (not as loud though) and can be slightly heard from 1,000 rpms to 2,000 rpms but from 2100 rpms to 2500 rpms you can really hear it whine. What do you guys think it is? Also another thing in the video, is at around 2 mins into the vid, i start flooring the gas pedal to allow it to downshift into 1st gear. Every time i do this the truck hesitates for a second. What do you guys think is causing this? Thanks again for the help and i hope the video link helps! Also, forgot to mention that the check engine light came on the other day for about five mins and went off. While the check engine light was one, it hesitated really bad. Took it to autozone (eng light had shut off by then) and the guy their said no codes were throwin.
Old Dec 8, 2009 | 08:23 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
if its cold where you are may be the altenator
was common on 04-05 trucks the whine sounds a lot like a whistle at different rpms
not answer on the tranny.
Old Dec 8, 2009 | 08:28 PM
bridge's Avatar
bridge
Sick 'n Tired
Wow. I hear several noises. One I think is the camcorder lens cover bouncing around on its tether. Another, a whine, sounds like a vacuum leak...a pretty bad one. Is you're truck 4wd? If so, I'd say that vacuum leak is causing IWE problems and you're losing vacuum to the hubs causing the other sound i hear, which is your hubs engaging, causing your transfer case to spin. The last is when you floor it. That sounds like a misfire or spark knock, and likely caused your check engine light. Find someone else with a better reader, so you can pull pending and stored codes.
Old Dec 8, 2009 | 11:16 PM
i eat hybrids
My truck is 4wd and sorry about the camcorder lol. But it doesnt feel like 4wd is engaged? So you think the whine is the hubs engagin? Whats IWE? Also i didnt kno that your comp stored CELS. The guy at autozone said that they didnt. What do you recommend i do?
i eat hybrids
Modular V10 (6.8l)
13
Jul 22, 2021 05:12 AM
nugent_crai
General Diesel Discussion
Jan 27, 2013 06:14 AM
badbrad60
Jan 11, 2010 10:47 AM
i eat hybrids
Modular V8 (4.6L, 5.4L)
Dec 9, 2009 04:02 PM
Robbgt
20
Mar 12, 2008 09:16 PM
