Sponsored by: Real Truck
How to remove and install Studs on Hub Assesmbly
Old Sep 24, 2009 | 08:59 AM
browntown3's Avatar
browntown3
Ok, i think i have narrowed down my problem to a bad hub assembly......Got to looking and cannot figure out how the 4 studs that hold the hub on can be removed or reinstalled??? Because they drive out from the back they can only go so far before hitting the hub assembly itself ? Am i missing something here ?
Old Sep 25, 2009 | 08:47 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Huh? Remove the nuts on the studs, and remove the entire hub with the studs attached?
Old Sep 25, 2009 | 01:00 PM
browntown3's Avatar
browntown3
I meant how to remove the 4 studs out of the old hub, I have to have them to go back into new one......I got to looking last night though and they apparently are screwed in and just have to be back out ( not as hard as i originally thought).........I will probably just buy some new ones from the dealer and not fool with trying to get them out.
Old Sep 25, 2009 | 01:14 PM
SpringerPop's Avatar
SpringerPop
Conventional wisdom says you're FAR better-off to just buy new studs from Ford.
They're about four dollars a piece.
It's sixteen dollars of grief you can avoid.
Pop
Racerguy
Aug 15, 2023 02:03 PM
sjwelds
May 12, 2016 08:40 AM
michael a
1947 and Older Ford Trucks
Dec 11, 2015 04:56 PM
Macs1964F100
Sep 10, 2014 08:25 PM
Headviking
Sep 2, 2014 06:44 PM
