alright im gonna be pulling the turbo next week ive already got the new o rings and bolts. the oil's started leaking on the ground and the valley is holding its share of oil as well. so what else shoud i do while im in there
But for real, check your up-pipes for leaks, if you some then look into bellowed up-pipes.
Check the turbo over, see how the shaft play is holding up. If you have surging, good time to put in a wicked wheel.
Maybe delete the EBPV, on the turbo and pedestal? Help elminate another possible oil leak.
And most importantly, give your engine valley a good, thorough cleaning! It'll help to detect leaks later on, and your truck will love you for it!
Adam pretty much covered everything to check, you could delete the EBPV by tac welding the flap, Meggawatt did this just recently and unscrew the plunger out of the pedestal and thread the hole and put a bolt in there. ronspowerstroke painted his valley for this reason I believe, wouldn't be a bad thing.
thinking about deleting the ebpv but dont really understand it. i was going to paint the valley would that be a good or bad idea
Here's what I did, wasn't the way I planned it, but it worked out for the better.
Instead of welding the flapper open, I took a dremel and ground off the rivets that hold the flapper to the shaft, that way no chance of me welding it closed. When I picked it up to move it the shaft fell out, so now I have a big hold in my exhaust. If I was at the farm I would have taken the mig welder and had it plugged in no time, but at home all I have is a stick, a little hesitant to do it, but I still got the job done.
On the pedestal, pull the snap ring and take out the plunger assembly. Like Mike said, tap the hold where the actuator rod went through, and find either a bold or in my case a set screw with a little bit of thread tape and stick it in there to plug it. Put everything back together and you're set! Just be sure to clean out all the filings from tapping it before you put it together. Don't want those flowing around with the oil.
I'm assuming you're planning on doing the pedestal o-rings too correct? It's be silly to be that far and not pull the pedestal and do those too.
If you are planning on a new wicked wheel or inlet housing, that's the time to do it. Adjusting the wastegate rod is easy while the turbo is out too.
I personally like my EBPV and wouldn't delete it, you might want a decel tunes one day. I'm not convinced there's a performance gain by removing it either; but if I were, I'd get a non-ebpv pedestal before I did all that plugging and welding. My two cents.
And if the boots are questionable, that's a good time to give a Clay a call for a new set.
yea im doing ped. o rings too. i really need to see where the oil is coming from when i get it all out. i noticed that on the drivers side head the hpx fitting has oil all over it so i may wind up having to tighten those down as well
