What kind of tranny should I get?
Old Jul 16, 2001 | 12:06 PM
GFunk's Avatar
GFunk
Hello all,
I am looking for a four speed tranmission to bolt up to a 78 351m. The problem is I don't know what I am looking for. What type should I get? By the way this is going behind a modified 351m so the stronger the better. Thanks for your help.
Old Jul 16, 2001 | 04:36 PM
billyb's Avatar
billyb
t-18, t19, or np435. these are tough and have granny first gears.
Old Jul 17, 2001 | 12:24 PM
GFunk's Avatar
GFunk
Thank you for the info biilyb but when it comes to transmissions I am lost. I guess I should have explained a little more. I am in the process of putting a 351m into a 76 f-150 that is two wheel drive. A couple of questions that pop into mind: are bellhousings easy to obtain and will I have to do any major modifications as far as the crossmember is concerned?
Old Jul 17, 2001 | 09:53 PM
billyb's Avatar
billyb
get in touch with a good recycling parts yard, they can hook you up. also check the classifieds right here. as a matter of fact, check here first!
you will need a bellhousing with 351m pattern, and a tranny to hook to it. there were lots of trucks built over the years, so stick to it and you'll get what you need.
Old Jul 17, 2001 | 09:56 PM
billyb's Avatar
billyb
oh yeah, the crossmember will have to be made if you can't get one with the tranny. depth of tranny will determine configuration of crossmember.
for example, i took a t18 2wd tranny out of my 88, and put in a 4wd overdrive unit, and the crossmember is not as deep as the old one. not hard to do.
Old Jul 18, 2001 | 11:50 AM
deere81's Avatar
deere81
If i was getting one it would be a NP435 because i know they are a heavy built transmission. its about the only 4 speed i've ever drove
Old Jul 18, 2001 | 01:56 PM
ringkong's Avatar
ringkong
Can't go wrong with an the IRON CASE T-18, just be carful puting it in, it is HEAVY. It should withstand any thing you throw at it.
Old Jul 19, 2001 | 11:31 AM
GFunk's Avatar
GFunk
Thank You for all the information. Wish me happy parts hunting!!!!
Old Jul 19, 2001 | 04:36 PM
71tallboy's Avatar
71tallboy
crakerjack51
Feb 23, 2008 04:33 PM
rsalter66
May 28, 2007 01:35 PM
1978f150sc351m
Jan 15, 2007 02:49 AM
Ranger73
Jan 13, 2007 01:17 PM
jth
Dec 8, 2001 10:42 AM
