Have a 83 f350 4x4 making a cluncking noise in front end when in 4wheel drive only. Have manual lock outs. Seems to jump out of 4 wheel drive at higher speeds only. Cluncking noise isn,t constant,but like every every half to a mile. Doesn,t clunk when locked out.
sounds like your lockouts might be bad that could be reason for it going in and out of 4 wheel also check your axle joints they may need to be replaced warn lockouts are good and if axle joints are bad use spicer they are the best hope this helps you out bad 78 f 250
you might want to check some local shops for price i did mine myself i have a buddy that is a mechanic he had the right tools to remove the hubs it took me about 4 hours to do it if you have access to the right tools it will cost about a $100.00 bucks for spicer axle joints but they are guaranted life thats why they cost more hope this helps you put up a post when you get it fixed let me no how it went bad 78 f 250
Thanks for your help bad 78 f250 I will let you know.I bought the truck just to use to haul wood. I remember when the guy I bought it from dad bought it brand new.Has a 6.9 Diesel 4speed manual power Up the wazoo.
