42 - 47 1.5 ton Steering Column Removal
Old May 14, 2009 | 08:40 PM
jdwoods's Avatar
jdwoods
Can someone tell me how to remove the steering column from a 42 -47 1.5 ton truck. I ran a search but did not find anything one it.
Thanks
Old May 16, 2009 | 10:59 AM
46fordtruck's Avatar
46fordtruck
If you want to remove the whole column, box and steering wheel you can do it with a little work. Disconnect the horn wire from the bottom, remove the drag link from the pitman arm, or just remove the pitman arm fromthe box, undo the 3 bolts holding the box to the frame. Then inside the cab remove the ignition wiring from behind the column drop and remove the 2 bolts holding the support to the bottom of the dash. After that you can kind of wiggle the box and all out of the cab. You can always remove the wheel first to give a little bit more room to work with.
Now if you are trying to get the column out with out remove the box, then that is very tough, there is not really any room to do that, the whole thing, box and all is removed all together
Old May 17, 2009 | 03:07 PM
jdwoods's Avatar
jdwoods
Thanks This helps.
Old May 22, 2009 | 10:11 PM
Snowking's Avatar
Snowking
I really coulda used that info while fighting with my 1947 Mercury halfton. Lets say it was a good thing I have 3 parts trucks. lol
white 66
1947 and Older Ford Trucks
Jan 16, 2017 07:10 AM
44jailbar
May 25, 2015 01:56 AM
1953EAB
Feb 12, 2014 10:25 AM
havi
Nov 3, 2013 05:15 PM
michellers
Jul 31, 2012 11:56 AM
