1978 - 1996 Big Bronco
92: Should a brake booster hold vacuum?
Old Apr 14, 2009 | 05:12 AM
muckypaws's Avatar
muckypaws
Hi,
I get the impression my braking isn't as good as it should be. I've changed pad/ shoes all round, master cylinder and front callipers over the past year or so and so started looking at other stuff. I put my vacuum pump/ gauge set on the booster and couldn't get it to hold a vacuum at all - not even a small one so I would assume its u/s? I would expect to be able to hold some vacuum in it - even if it leaks out over time.
The hose from the manifold tee and the booster check valve is fine (unfortunately!)
Thoughts?
Simon
Old Apr 14, 2009 | 07:57 AM
alxsnmr's Avatar
alxsnmr
It holds vacuum until you step on the brake. Make sure the grommet around the check valve hasn't cracked or broken. If you have soft brakes I wouldnt think the booster would be the problem as it is for making it easier to brake the vehicle. What kind of brake issues are you experiencing?
Old Apr 14, 2009 | 08:52 AM
AbandonedBronco's Avatar
AbandonedBronco
The fact that it doesn't hold vacuum doesn't seem right, but as said, if your booster is going out, your brakes are rock hard. The booster basically amplifies the pressure your foot puts on the pedal to make braking easier, so if it goes out, the pedal is much harder to press.
That being said, Broncos are not known to stop all that well as it is (unless you have squishy brakes).
Old Apr 16, 2009 | 11:59 PM
Aciancio's Avatar
Aciancio
when you changed the master did you find any fluid around the rear seal between the master and the booster? I had a booster fail before where it put vacuum on the rear seal of the master causing the booster to fill with brake fluid and the brakes to be squishy as hell. my bronco on the other hand, when the booster on it failed I had to make a fast choice between a honda civic or a ditch.
