94 ranger weird noise
Old Mar 2, 2009 | 04:34 PM
slomafarms's Avatar
slomafarms
i just test drove a 94 scab v6 auto trans ranger today and i was wondering about a weird noise coming from the rear of the truck...dont know if its the trans or rearend...its a clicking noise, clicks faster the faster you go...its not loud but noticeable
Old Mar 2, 2009 | 06:08 PM
michigan66's Avatar
michigan66
Did you look at the driveshaft, especially the U joints, to see if something is wrapped around it and is hitting the body as the shaft or joint turns. I could be something loose in one of the brake drums that is rattling. Does the sound seem louder on one side of the truck that the other side? It could be a nail or bolt stuck in a tire, as well. Jack up the rear end, start it up and put it in gear. Walk around the truck and see if you can locate the sound. If it seems to be around a wheel, shut everything down. Turn each wheel by hand. Does anything rattle or squeak? If you have hub caps, pull them off to see if lug nuts are loose/ if the wheel is loose. Feel around the tread and edges of the tires to see if something is sticking out of them. Let us know what you find.
Old Mar 2, 2009 | 07:04 PM
slomafarms's Avatar
slomafarms
when i drove it, it seemed to have good brakes...for the miles that it had it ran great! if i buy it ill look into it and let you guys know what it is....thanks fot the things to look for
fordfan302
Jun 9, 2013 03:42 PM
93f1505.0L
Jan 20, 2006 08:47 PM
Big 89 Bronco
1978 - 1996 Big Bronco
Dec 16, 2002 07:03 AM
RBrendel
16
May 11, 2002 09:25 PM
