Tires? Max load at 50 psi
Old Feb 5, 2009 | 01:42 PM
whiteaddiction's Avatar
whiteaddiction
Does the max load at 50 psi on the side of the tire mean I can't run my tires up to 60psi? I am running my tires around 65psi for all four since I don't haul a lot. But if I wanted to, the max load would be less? I have load range D's they are suppose to be E's.
Old Feb 5, 2009 | 02:51 PM
884x4broncoII's Avatar
884x4broncoII
there should be another spot on the tire that says what the max psi is, also your tires can handel more weight at max psi than at an lower psi because the tires wont bulge as much and make them run cooler
Old Feb 5, 2009 | 03:38 PM
putz54143's Avatar
putz54143
50 psi is ok if your not haulin anything, look on the sidewall it will tell you the weight you can carry per tire at that air pressure. do you have LT tires or p metric
HRTKD
All Things Towing
Mar 25, 2017 01:21 PM
Resendiz
Oct 8, 2016 12:20 PM
tony montana 42
6.7L Power Stroke Diesel
Aug 10, 2016 01:34 PM
Ron94150
May 15, 2016 03:42 PM
glsurratt
18
Aug 10, 2006 01:23 PM
