Those running Rotella syn
Old Feb 3, 2009 | 06:45 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Do you just swap the filter and add a few quarts at 3000 or do you change everything out?
I'm do for an oil change and thinking of making the switch to syn.
Old Feb 3, 2009 | 06:53 PM
caleb90's Avatar
caleb90
Temporarily Deactivated
when i made the switch,i changed the filter put my 15 quarts in ran her for 3000 miles.Droped the oil again changed the filter and put 15 new quarts in it,and im going to run this for 5000 miles.I didnt want to run it more than 3k after i first made the switch because i always herd that syn oil and dyno oil dont mix well.hope this helps and others will chime in to give you there opinions.
Old Feb 3, 2009 | 06:55 PM
whitewhale's Avatar
whitewhale
Interested myself, just switched to Rotella Synthetic last oil change.
Old Feb 3, 2009 | 06:56 PM
61 uni's Avatar
61 uni
Most if not all oil brands make a synthetic blend. They can't mix to badly.
Old Feb 3, 2009 | 07:22 PM
big poppa's Avatar
big poppa
Get the truck up to operating temps, change the oil and filter being careful of the hot oil and refill with the synthetic and your on your way. When i switched over to synthetic from dino i went 5000 on the first synthethic change then to 10,000 intervals after, good luck.
Old Feb 3, 2009 | 07:57 PM
DR JOE's Avatar
DR JOE
Big Poppa,
Do you drop and replace the filter at 5000???
Doc.
Old Feb 3, 2009 | 08:28 PM
big poppa's Avatar
big poppa
Originally Posted by DR JOE
Big Poppa,
Doc.
Whenever i change the oil, the filter gets changed also. I run 10,000 miles and oil and filter get changed also, on the synthetic that is. So no, i keep the filter in there the full 10,000. I started the synthetic at 15,000 miles and i got 112,000 with no problems. I,m going to run an oil analysis on this oil change to see how everythings doing in there. Theres a few fellas on here that got oil test to see how there oil is working in their trucks and they should be by soon.
Old Feb 4, 2009 | 06:44 AM
Supercab's Avatar
Supercab
Wink
I don't think there is any need to mix dino and syn anymore to get engines and seals used to it.
Years ago when synthetic was first on the market it would basicly clean everything up inside the engine including the seals, and IF there was anyplace that was kind of plugged up by the dino oil the synthetic would find it and you'd have a leak.
That was then and this is now, synthetics have come a long way, everyone that I have spoken with just changed to the synthetic all in one oil change including the filter, and everything was alright with no problems, I have heard that some people use dino in summer and synthetic in winter, but here in Florida I swaiched to synthetic and never plan on switching back, I use the Shell Rotella mainly because its so redily available at Wal-Mart.
Old Feb 5, 2009 | 05:56 PM
F-250 Super Duty
Any particular oil filter you using? I'm still using the Motorcraft FL-1995.....
Old Feb 5, 2009 | 06:01 PM
87 F-150 I6's Avatar
87 F-150 I6
That oil filter will work just fine, that's the one I use with the syn. I also just switched did not mix.
Old Feb 5, 2009 | 06:07 PM
King0581's Avatar
King0581
Everybody I've heard about is using the same filter they always have after switching to synthetic.
Old Feb 5, 2009 | 07:15 PM
Izzy351's Avatar
Izzy351
No need to mix -- just drain, change filter (put almost 2 quarts in the filter), then put the rest in the engine. Run as usual. I generally change mine at about 7k so I don't have to screw with OAs (Oil Analysis). I think if you're going to push it (even syn) past 8k, you should be checking things with an OA, but that's my own opinion. I prefer to KNOW I have good oil in there, while compromising on a little longer OCIs over dino.
Good luck! You'll love the syn -- made a nice difference in how my truck runs, so it's worth it to me. When you do yours, put a little fresh dino and the same amount of fresh syn in a container you can see through and put it outside (if it's cold out) or in the freezer if it's warm. After the samples are nice & cold, try pouring both out. You'll be convinced.
Oh, and I use nothing but Motorcraft filters.
Old Feb 5, 2009 | 07:53 PM
panteramatt's Avatar
panteramatt
WTF?? I live in Elsinboro too! Small world. I use rotella T and the motorcraft filter is one of the better ones out there.
Old Feb 5, 2009 | 09:24 PM
F-250 Super Duty
You live along the river?
Old Feb 5, 2009 | 09:30 PM
rebelchevy02's Avatar
rebelchevy02
I have rotella synthetic in mine, and been so for a while. Last two changes, I sent in at 7500 miles, to Blackstone, to get analyzed. They said both changes were well below the average PSD, and to run to 10k the next change. Mind you my next change will probably be next month, on its 200k birthday. I feel as though I should wax it.
