Dumb question, stock radio...
Old Jan 29, 2009 | 09:56 AM
Xerophobic's Avatar
Xerophobic
...how do you set the time? I have no owners manual and the "typical" ways to do it dont seem to work.
And yes I feel dumb thanks
lol
Old Jan 29, 2009 | 11:28 AM
billygoat's Avatar
billygoat
it might depend on what model radio you have, however, for my stock indash 6CD player, you hit the menu button until "set hour" (or something similar to that) and then use the up/down arrow button to set the hour. Then hit the menu button again until the "set minutes" option and set with the up/down arrow button.
Hit the "menu" button again until you are back to the normal radio display...HTH
The Big Bad X's Avatar
The Big Bad X
its pretty simple, you hit menu on lower right corner, until you see adjust hour, use the up and down buttons to adjust, then hit menu again till you see adjust minutes
Old Jan 29, 2009 | 11:36 AM
Xerophobic's Avatar
Xerophobic
May be a different model. Here's my radio
Old Jan 29, 2009 | 11:55 AM
housedad's Avatar
housedad
Email me and I can send you a PDF copy of the owners manual. Just tell me what year(s)
Bion
Old Jan 29, 2009 | 12:05 PM
Cardiac69's Avatar
Cardiac69
To set the hour, press and hold the
CLK control and press SEEK:
< to decrease hours and
> to increase hours.
To set the minute, press and hold
the CLK control and press TUNE:
< decreases minutes
> increases minutes
Old Jan 29, 2009 | 12:20 PM
Xerophobic's Avatar
Xerophobic
Thanks a ton guys, just what I needed.
Its a 2000 V10 4x4 Bion, and Im also needing a fuse box diagram unless thats in the owners manual and I suspect it probably is.
email is :
jetboatin at yahoo.com
Cheers
Old Jan 29, 2009 | 12:31 PM
housedad's Avatar
housedad
Check your Email. I sent the 2000 and 2002 books. The 2002 is a bit better to search with.
I also sent the Ford 'Drive your SUV' supplement that discusses dirving in 4WD/ It was a original book that came with the Ex.
I also sent a copy of the 2005 Excursion Maintenance schedule from Ford. I have checked them, and it is the same for all years.
Old Jan 29, 2009 | 12:37 PM
Xerophobic's Avatar
Xerophobic
That is awesome thanks so much!
Never ceases to amaze me how useful these forums are. God what did people do before they existed!? haha I must be a member of a few hundred for everything under the sun.
Cheers and thanks again
