swapped from 265's to 245's
Old Jan 24, 2009 | 08:07 PM
wrenchturner's Avatar
wrenchturner
i finally had time to swap my tires. i yanked off the stock conti's and mounted the michelin ltx 245/65/17's that i had. The truck runs great. seems to handle better. the tires i put on are load range E. so the are considerably stiffer. the ride is firmer, i have them inflated to 45psi, the side wall says max 80. If i hook the big trailer on I may add air. but being it is the wifey's ride she may not like the teeth rattleing ride it would give.
Old Jan 24, 2009 | 09:47 PM
briank's Avatar
briank
If your original tires were 265/75R17 then your speedometer is going to be off by about 7%.
Line 1 is stock tire and line 2 is new tire.
Stock Tire - 265/70R17
New tire - 245/65R17
Section Width: 10.43 in 265 mm
Section Width: 9.64 in 245 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 7 - 9 in
Rim Width Range: 7 - 8.5 in
Overall Diameter: 31.60 in 802.64 mm
Overall Diameter: 29.53 in 750.06 mm
Sidewall Height: 7.30 in 185.42 mm
Sidewall Height: 6.26 in 159.00 mm
Radius: 15.80 in 401.32 mm
Radius: 14.76 in 374.90 mm
Circumference: 99.27 in 2521.4 mm
Circumference: 92.77 in 2356.3 mm
Revs per Mile: 658.2
Revs per Mile: 704.3
Actual Speed: 60 mph 100 km/h
Speedometer1: 64.2 mph 107. km/h
Speedometer Difference: - Speedometer Difference: 7.003% too fast
Diameter Difference: - Diameter Difference: 6.56%
Old Jan 26, 2009 | 05:10 PM
wrenchturner
i thought the originals were 265/70/17's. i now have 245/70/17's.
the tire calc i used says it was off by 3%. i have no plans on long distance travel in the truck. i doesn't get driven much actually. it will to the boat to the loacl watering holes and back and some demo cars in the summer.
