shorter=louder for glasspacks?
Old 03-20-2002, 09:27 PM
fordtruckin's Avatar
fordtruckin
fordtruckin is offline
Hey just curious, the shorter your cherry bombs are, the louder right? IE 36" CBs will be quieter than 24"?
Old 03-21-2002, 07:32 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
it depends. it will be louder, but it will have that crackle. i've seen longer glasspacks that get just as loud, but they put out that deep low moan(the kind that makes the hair on you neck stand up). I'de go with the longer glasspack, but run a straight pipe without Cats. It will sound better...i think
Old 03-22-2002, 12:15 AM
fordtruckin
Oh yeah it'll be a straitpipe.... actuall it'll be the glasspack welded on to the end of the header and a turndown on the end of the glasspack. One off each header and that's my exhaust! And the truck this will HOPEFULLY be going into is a '72 F-100 shortbox with a 428. I'm going to look at the truck on saturday I can't wait.
Old 03-22-2002, 10:20 PM
oldblue18's Avatar
oldblue18
oldblue18 is offline
Yes, shorter is louder...and shorter is also more "high pitched". On my F-150 I have true duals with 12" glasspacks. I pulled along someone with straight pipes and could not tell any difference between the two....
Jon
1989 F-150 XL- 4x4, 302, M50D--New and Improved with 3" body lift...and worn out 31" tires....
1995 Bronco Eddie Bauer- 351W, E40D
Finally got around to creating a gallery...check it out
Old 03-23-2002, 03:22 AM
fordtruckin
Yeah.....well I'll have cutouts so I think I'll go with the longer glasspacks. I was going to put flowmasters on but if it's an older truck it needs that rumble and the flowmasters just dont' give you that. Thanks alot for your responses!
Old 03-23-2002, 03:59 PM
dewey_gubbels's Avatar
dewey_gubbels
dewey_gubbels is offline
Bdox
06-12-2008 01:55 AM
jake00
02-25-2007 02:21 PM
slothshady
Exhaust Systems
06-11-2002 12:39 PM
Quick Reply: shorter=louder for glasspacks?
