New water pump
Old Jan 20, 2009 | 06:04 PM
Rus01's Avatar
Rus01
New water pump
i just finished changing my water pump in my 7.3. got it all finished and relized i used the old water pump gasket!!!!! Grrrrr!!! should this be ok long term??
Old Jan 20, 2009 | 06:06 PM
Kwikkordead's Avatar
Kwikkordead
Not as good as using the new one. If it is holding right now you might get away with it.
Old Jan 20, 2009 | 06:35 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
What were you thinking Rus? lol This happens, if its not leaking you may get away with it like Dan said. I would wait till it leaks before changing it. You do know how to change it now.
Old Jan 20, 2009 | 07:08 PM
Rus01's Avatar
Rus01
everything went so well changing it!! 2.5 hours complete!! and then this happens! Grrrrr! like you said, at least i know how to change it know! hopfuly it will hold! i think it should be ok.
Old Jan 21, 2009 | 07:48 AM
mueckster's Avatar
mueckster
If the gasket looked "that good" that you mistakenly re-installed it, you should be OK. I replaced my W/P at 98k miles and the "new" gasket started seeping, at the top, and I had to replace it 50k miles later. Went ahead and put another new W/P on there for good measure. Gasket was only $5, but I didn't want to have a "do over'', later. It looked a little "iffy" around the weep hole.
Old Jan 21, 2009 | 09:07 AM
vettdvr's Avatar
vettdvr
As previous if not leaking drive on. We have all had our phopas,,, While doing the 4wd front hub replacement I put the backing plate on backwards and didn't catch it until I could not get the rotor on.,, then had to pull the bearing and axle back out to install it correctly. Drive on.
Old Jan 21, 2009 | 09:10 AM
bobmiers's Avatar
bobmiers
I just replaced my as well. Took me a bit longer, but I suspect that I older and slower <g>.
Bob
Old Jan 21, 2009 | 09:33 AM
vettdvr's Avatar
vettdvr
Originally Posted by bobmiers
I just replaced my as well. Took me a bit longer, but I suspect that I older and slower <G>.
Bob
Older and slower worked for me.
over 60
over 3 days to do the work
over 150 for NEW pump to do the job
no leaks, no drips, driving on.
So Older slower might just be ok!
Old Jan 21, 2009 | 10:50 AM
mueckster's Avatar
mueckster
Better to be a bit slower and do it right than hurry and spend more time doing it over. Quality work comes with patience and skill.
Old Jan 21, 2009 | 10:56 AM
vettdvr's Avatar
vettdvr
Maybe this comes with wisdom through age and bad experience.
Old Jan 21, 2009 | 11:32 AM
mueckster's Avatar
mueckster
Been there, done that!
Old Jan 21, 2009 | 11:51 AM
bobmiers's Avatar
bobmiers
That is what happened to me... no leakes - so far. Biggest problem was standing on my short ladder to be able to reach over the front and that blessed hood latch jabbed me in the gut......
Bob
Yeah, I know I should have covered it with some padding... live and learn
Bob
Old Jan 21, 2009 | 11:54 AM
vettdvr's Avatar
vettdvr
Bob
Bob
My son gave me a Top Side Creeper. It is great for working under the hood of the Excursion 4wd. The truck is high and I have a bad back. I used this to do my water pump. Took 3 days and had no back issues. You might consider one.
Topside Creeper
<TABLE cellSpacing=10 cellPadding=0 width="100%" border=0><TBODY><TR vAlign=top><TD style="WIDTH: 20%" align=middle></TD></TR></TBODY></TABLE>
Old Jan 21, 2009 | 12:17 PM
bobmiers's Avatar
bobmiers
I've seen that item before... just don't have the space to put it... it does seem to prevent the problems that I encountered.
Bob
Old Jan 21, 2009 | 01:27 PM
vettdvr's Avatar
vettdvr
Bob
I haven't used it much but it really is a back saver. I had to make a place to store it. My kids gave it to me as a gift so I would not hurt my back.
