Knocking or Bumpy noise from front suspension - 97 EB Expy
Old Jan 1, 2009 | 09:57 AM
pcguy760's Avatar
pcguy760
Question Knocking or Bumpy noise from front suspension - 97 EB Expy
While driving, I started to hear / feel this knocking / bumping sound coming from somewhere in the front suspension. It gets louder at lower speeds (less than 30 mph) but I can barely hear or feel it at 60mph. The knocking also stops when I make turns but starts again when I am driving straight. Seems like it has got louder after a 15 miles journey too.
What do you guys think it might be?
Thanks,
Mo
Old Jan 1, 2009 | 11:55 AM
alloro's Avatar
alloro
A worn front axle CV joint would be my best guess.
Old Jan 1, 2009 | 12:47 PM
pcguy760's Avatar
pcguy760
Exclamation
Hmmm - I thought a bad axle would do that while turning also? It does not knock while turning...wierd.
Old Jan 1, 2009 | 09:24 PM
WALJON's Avatar
WALJON
I would check out your front torsion bars I had one break and it did the same thing.
Old Jan 1, 2009 | 10:51 PM
Gevans17's Avatar
Gevans17
mine was due to both front shocks were broken where they attach to the lover control arm.
Old Jan 2, 2009 | 10:33 AM
Icefan71's Avatar
Icefan71
I had a broken sway bar link that caused a knocking sound like you described.
Old Jan 2, 2009 | 11:55 AM
alloro's Avatar
alloro
Just the opposite. While turning, you are putting more of a load on the CV joint causing any slack within the joint to be taken up. The joints are at their loosest when they are straight.
Old Jan 2, 2009 | 01:59 PM
pcguy760's Avatar
pcguy760
Lightbulb
Thanks for all the input guys! I will go check everything you guys mentioned and respond with my input later on.
Old Jan 2, 2009 | 05:00 PM
pcguy760's Avatar
pcguy760
Unhappy
Well I just checked everything under the front suspension and everything appears to be in good condition. Nothing looked broken. As for the axles, both "appeared" to be normal...
I took it out for a drive and the noise was gone for about 1 minute and then it came back for good. I am no expert at suspension stuff - any ideas what else I should do or check? Thanks!
Mo
Old Jan 2, 2009 | 05:59 PM
FOUNTAIN 1's Avatar
FOUNTAIN 1
Check youre bumper , just a thought
Old Jan 2, 2009 | 07:52 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
Probably wouldn't hurt to have the alignment checked. A good trustworthy place should be able to find whats loose.
Doesn't hurt to just crawl around the engine compartment and underneath grabbing stuff looking for a loose part. Good luck
Old Jan 4, 2009 | 12:47 PM
pcguy760's Avatar
pcguy760
Lightbulb
LOL, you are kiddin right?
Old Jan 4, 2009 | 12:49 PM
pcguy760's Avatar
pcguy760
Yeah I did that as mentioned in the previous post. I even lubed up some of the joints, etc. - still no go . I am just gonna take it in tomorrow and get a "diagnosis" as they say...
Fisher Roofing NJ
Jan 18, 2014 02:10 PM
10rowdy10
May 18, 2012 08:16 PM
DavidE79
Mar 16, 2011 12:17 AM
garymocwi
Jul 16, 2005 05:50 PM
firestorm
Aug 19, 2002 05:48 AM
