3.03 3 speed parts source
Old Dec 9, 2008 | 06:50 PM
wickedinhere's Avatar
wickedinhere
Does anyone have a place to get parts for the 3.03 3 speed?
Old Dec 11, 2008 | 05:52 PM
85e150's Avatar
85e150
Google "transmission rebuild kits" and find this and a host of others:
Tremec 3 Speed Manual Transmissions manual transmission part, rebuild kits and overhaul kits
I didn't look at what they offer, but it's probably rebuild stuff up to synchros. If you need gears/shafts, best head to the scrappy and find another box, or consider a different trans.
Good luck.
Old Dec 11, 2008 | 06:07 PM
wickedinhere
Thanks i found that today. I have been tryng to search but my browser got hijacked
so my search kept coming up with trash sites but its fixed now. I am just gonna replace seals and the gaskets while i have it out changing the clutch.
Old Dec 11, 2008 | 06:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since Ford used the 3.03 M/T on cars from 1963 thru 1980 and on trucks from 1963 thru 1996, I doubt you'll have too much trouble finding parts for it.
What year is the trans, what's it from, and what do you need?
C3AZ-7153-G .. Gasket Set fits 'em all, the front/rear bearings (C3AZ-7025-C & C3AZ-7025-B) are the same.
The input shaft needle bearings (15-C3AZ-7118-A) are the same as are the countershaft needle bearings (50-C3AZ-7121-A).
The syncro blocker rings are the same (1-C4AZ-7107-D 1st gear blocker ring / 2- C4AZ-7107-C 2-3 blocker ring) are the same, as are all the snap rings & washers.
The seals are different, it depends on the year/application.
I can give you autoparts store (Industry) numbers for some of these parts.
Old Dec 11, 2008 | 06:54 PM
wickedinhere
Its out of a 68 f-100 with a 240-6. I need all the gaskets/seals including the rear rear seal.
Old Dec 11, 2008 | 07:12 PM
NumberDummy
The following parts are available from NAPA which can cross the Ford numbers over to the brands they sell.
C3AZ7153G .. Gasket Set
C3AZ7025C .. Front Bearing
C3AZ7025B .. Rear Bearing
D9BZ7052A . . Replaced: C4TZ-7052-A .. Extension Housing Seal
B3TZ7A034B .. Extension Housing Bushing
D8UZ7A283B .. Replaced: C9AZ7A283A .. Front Seal
Old Dec 11, 2008 | 07:35 PM
wickedinhere
Thanks, napa isnt to far from me.
Old Dec 12, 2008 | 04:09 AM
NumberDummy
TYPO alert.
The gasket set is C3AZ7153F not C3AZ7153G
muth_33
Feb 29, 2016 09:16 AM
Fellenz
Feb 7, 2015 02:49 PM
Eagle299
Oct 9, 2014 11:06 PM
Early 1969
21
Nov 8, 2013 11:25 PM
David B.
Feb 24, 2012 04:57 PM
