Sponsored by: Real Truck
Can't figure out this noise
Old Dec 5, 2008 | 09:33 AM
Miketnf150's Avatar
Miketnf150
My father in law has 03 (Last year of the 7.3) F250 4dr. I've searched but can't really figure out this noise. We've thought it was a tire noise like if you are running mudders but the more I listen to it I don't think that's it. I don't think it's a u-joint because it's a constant noise. It's really bad when it's around 65-72. When I let off the gas it quitens down quite a bit but is still there. I'm kind of thinking it's a bearing but to me a bearing going bad should be a constant whinning sound. It also goes away when the truck downshifts and the engine jumps to a higher RPM. He's starting to think it may be the OD gear/bearing.
So has anyone experienced this kind of noise?
Edit: It's been a while since I've been here and didn't see the 99-03 SD thread so if someone wants to move this to there feel free.
Old Dec 5, 2008 | 01:58 PM
Big Orn's Avatar
Big Orn
Mike,
Is it 4 wheel drive?
So - the noise goes away completely when it downshifts?
Have you checked to see if the noise is still there when running 65-70 in a lower gear? If the noise only happens when going that speed and in OD, then he may be right.
Old Dec 5, 2008 | 02:15 PM
superduty4x4's Avatar
superduty4x4
Wish I could help, but I've not heard of anything similar to what you are describing... the 99-03 7.3 forum is still here you just have to scroll down a ways to get to it.
Old Dec 6, 2008 | 01:10 AM
Miketnf150's Avatar
Miketnf150
Big Orn,
yes it's 4WD and I hit the OD button on the shifter to take it out of OD and it went away some. I could tell there was still a noise but not as bad.
Old Dec 6, 2008 | 05:47 AM
Fordsflylow's Avatar
Fordsflylow
Have you checked the obvious - tires? Try rotating them first and then go from there diagnosing. I've had a tire or two go bad that were fairly new. When rotating and before taking the front wheels off spin them and look dead on down the front of the tire at the tread groove while spinning to see if there is any wobble from something like a broken belt or cord.
My next check would be bearings, hub or wheel.
Good luck
Old Dec 6, 2008 | 11:53 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Hanger bearing?
Old Dec 6, 2008 | 07:20 PM
Miketnf150's Avatar
Miketnf150
Originally Posted by krewat
Hanger bearing?
Splane please!!!
Fordsflylow,
He's rotated the tires and still does it. He's trying to find someone that has a different set that would let him borrow them just to put them on and drive down the road and see if the noise is still there.
Old Dec 6, 2008 | 07:28 PM
Toyman's Avatar
Toyman
How many miles on the truck, and when were the front bearing last replaced. I would lean to that more than transmission. I'm thinkin needle bearings in the wheel bearing assembly.
Toyman
Old Dec 7, 2008 | 03:49 AM
Miketnf150's Avatar
Miketnf150
Toyman
I believe it's got a little over 65K but not sure. This is something I was leaning towards until I drove it a while and playing with the speed and RPM's I've kind of ruled them out.
Old Dec 7, 2008 | 05:10 AM
redford's Avatar
redford
Does the noise go away of you lock the front hubs?
Old Dec 8, 2008 | 12:16 AM
Miketnf150's Avatar
Miketnf150
Haven't tried this one yet! I'll let ya know!
Old Mar 13, 2009 | 12:53 AM
Miketnf150's Avatar
Miketnf150
Sorry it's been a while but finally got the noise taken care of.
Took the truck to a shop and the mech. thought it was the front bearings. Tore into it and replaced both sides and still not solve. Come to find out the rear carrier bearing was wore out. Luckily it didn't get the gears. So after a $2000 bill problem solved.
Thanks for all the input guys.
Old Mar 13, 2009 | 04:54 AM
Fordsflylow
Originally Posted by Krewat
Hanger bearing?
Looks like you were right on Krewat!
Old Mar 13, 2009 | 05:56 AM
bubbasz1's Avatar
bubbasz1
Not that it matters but the carrier bearings are in the rear diff, the hanger bearing supports the center section of the two piece driveshaft. The carrier bearing would have been way cheaper though.
Old Mar 13, 2009 | 08:24 AM
Scottay's Avatar
Scottay
I am going thru something very similar. A whirling noise (from underneath, near the center to rear - hard to tell) that changes pitch with wheel speed. Thought it was the rear wheel bearings. Just finished replacing the rear wheel bearings last night to find out that was not that problem. It dose it in all gears and in neutral without a change in noise or pitch, so I ruled out the transmission. I am hoping its the driveshaft u-joint(s) or center bearing, but thinking its a carriage bearing, and dreading its a pinion shaft bearing. It started after the truck was parked for a week at the airport at close to a week of single digit temps. As soon as it started to roll I heard a very small quick dry "crack or snap" and that when it started. At this point, I am ready to take it to Ford for diagnostics, before I just start throwing more parts at it.
