03 Navigator Air Suspension Issues
Old Oct 22, 2008 | 11:38 AM
peddler96's Avatar
peddler96
I was wondering if any on else has had this issue? The drivers side in a couple of inches lower than the passenger side and at times the suspension will work fine (stayed aired up) and the other it partially dumpes and I get the Check sus light.with the drivers side 3-4 inches lower than the passanger. I sparyed the drivers bag and lines cant find any leaks. But found a leak at the dryer thanks to the stealer leaving the bolts out on the window washer box and it resting on the compressor. From doing a search I couldnt find any poss answers, and just dont want to start replacing parts for no reason. Hope you guys have some suggestions that will help..
Old Oct 22, 2008 | 12:11 PM
alloro's Avatar
alloro
The solenoid valve for that corner is probably working intermittently.
Old Oct 22, 2008 | 01:06 PM
peddler96's Avatar
peddler96
I can hear air rush from the drivers front suspension when I was driving slow with the window down, a sush sound but its intermittiant only, could the solenoid cause that?
Old Oct 22, 2008 | 03:20 PM
alloro's Avatar
alloro
The release solenoid could. I would think that if it were a leak in either the airbag or an air line, it would always leak. Since it sometimes will work correctly, I'd rule out a leak and pursue the only other thing that will release air...the solenoid.
Old Oct 22, 2008 | 05:55 PM
peddler96's Avatar
peddler96
Is there a way to check the solenoid or just replace it, and then have the system recalabrated? Thanks again
