I had a thought,now what do you all think?
Old 08-19-2008, 07:06 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
I was doing some thinking the other day and would like to know what you guys think.My dad was in the water treatment buisness for about 20 years therefor I got to thinking about the equiptment and material that was used to neutralize acidic water. the material was basicly crushed oyster shells and that is basicly all calcium. this substance would raise the PH of water from anything from a 4.5 up to a neutral 7.0 just by passing through it. that being said here's my question.. Would this stuff work on wvo to bring up the PH from high FFA. would it have any adverse affects on the oil or Biodiesel production. I plan on trying this by perculating the oil through a mixture of calcite and this oyster shell material. I want to try this due to the crappy oil that I've been getting lately just as another option for high titrate #s. I do know that the material would desolve into the water to raise the ph and then was filtered out leaving ph 7.0 water. I wanted to get some feedback as to what you guys "fabman" thought about this and if you think it will work. thanks for any info and I'll post some results once I try it this weekend. the material is about $50.00 for 50 pounds but it lasted for several thousand gallons of water, maybe it will work for WVO.
Old 08-20-2008, 09:07 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Oyster shells contain calcium carbonate which is an ionic compound so it is soluble in water. When it dissolves it forms Ca(OH)2 a base which raises the ph of the water solution.
Calcium Carbonate is not soluble in oil so it cannot raise the ph.
Good idea but the chemistry is not right.
99ExpyProblems
09-01-2018 07:45 AM
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
natedog37
03-08-2011 12:00 AM
vervepipes
08-20-2010 09:57 PM
stretch five oh
2004 - 2008 F150
06-05-2005 05:49 PM
Quick Reply: I had a thought,now what do you all think?
