1978 - 1996 Big Bronco
bad rear whl bearing info needed
Old Aug 12, 2008 | 11:02 PM
X36's Avatar
X36
Hi all went for the state safety inspection/discovere R/R wheel bearing is real bad.Tire moves all around when off the ground.My question is that the openng for the bearing is now warped.Does this mean I'm going to need a new axle housing or do they make something like the bearing buddy that folks use on trailers Thanks
Old Aug 13, 2008 | 01:21 PM
NWBronco's Avatar
NWBronco
YOu did not mention the axle type. 8.8" or 9"? The 8.8" is c-clipped in the diff. The 9" has a lock collar behind the wheel bearing. Have you disassmebled it all and looked it all over? If the axle tube is shot, you'll need need to eith replace the tube or the entire axle housing. And...if you have the bug... then now is a good time to look for a full floater, like a Dana 60 or a 14 bolt.
Bob
Old Aug 13, 2008 | 01:59 PM
andym's Avatar
andym
If the end of the axle tube is warped you need a new housing, no way around that. F-150 and Bronco axles will interchange, so get either one from a junkyard. Inspect it first so you don't get a worn out axle. Also make sure your gear ratio matches the old one, you don't want to run two different ratios.
And unless you need the strength or like carrying two spare tires around, it's kind of dumb to upgrade to an 8-lug axle.
Old Aug 13, 2008 | 02:22 PM
NWBronco's Avatar
NWBronco
It's not that hard to replace the axle tube itself. He can shop around for a replacement axle. complete. The 8.8" will flop around a bit if it's a limited slip and worn completely out. There will be signs of the bearing failure though, like gear oil leaving at a rapid rate. Hence, my comment about tearing it down and looking at it real good.
Bearing repair kits are available. And I'm okay being considered 'dumb'. Heheh, believe me, you are not the first, and you won't be the last.
Bob
Old Aug 13, 2008 | 02:47 PM
andym's Avatar
andym
Maybe I should have phrased that (a lot) better.
I didn't mean to say that you were dumb. I'm sorry if you interpreted it that way. What I should have said was, "it might or might be practical to upgrade to an 8 lug axle in this guy's case".
Replacing the tube might not be that hard, but I think you need to pretty much gut the axle and remove it from the truck, right? At that point, just get another axle. Maybe now would be a good time for some upgrades.
Old Aug 13, 2008 | 02:52 PM
NWBronco's Avatar
NWBronco
It's all good. I've swapped tubes with the axle still in the rig. It's a pain though, and easier to drop the axle and place it on a stand and do the work standing upright.
Old Aug 13, 2008 | 03:35 PM
McLeod's Avatar
McLeod
All the trucks in the OP's gallery are 250's or 350's, so chances are that he already has an 8 lug full floating axle.
Old Aug 13, 2008 | 03:38 PM
andym's Avatar
andym
Except this post is in the Bronco forum.
Old Aug 13, 2008 | 04:38 PM
X36's Avatar
X36
OK thanks for all the feedback.I wanted to know what I'll be in for before I start taking it a part.It's a 79 Bronco.Regards
Old Aug 13, 2008 | 05:58 PM
NWBronco's Avatar
NWBronco
'79 has the 9" rear. The alxeshaft is held in by the backing plate behind the wheel bearing.
THis could be a problem.
