I am looking for some help with a cost effective solution for lowering my 47, it sits way too high. I have already converted to disc brakes up front and power steering box and the rear has been changed out to a 12 bolt c**v model, but still retains the multiple leafs(about 10 front and back and the lever shocks. So I am looking to see what the best solution is for springs(aftermarket seller or local spring shop) and shocks I would need to find upper frame brackets for front and rear as well as lower mount for each or a shock bar across the back between the frame. Any suggestions would be a great help. I am not interested in an IFS at this time.
Thanks
My strongest suggestion is to talk to the folks at Chassis Engineering. Are you planning to keep the flatty ???
I used a 4" drop axle up front, a reverse eye transverse spring up front. In the rear I used a Posie's parrallel leaf spring setup and eliminated the rear transverse spring. Chassis Engineering has complete front and rear kits for these setups.
P.S. Be sure and tell the folks at Chassis engineering that you converted the front brakes to discs. It will probably make a difference in your steering arms and the disc brake caliper brakets. You have to keep the drag link and front tie rod as near parallel as possible.
Reason: Additional thought
Thanks for the info 41 in WV. Your setup is different to the 47 pickup and I have started to look at the chassis engineering parts. The truck currently has a 302 and C4 setup.
3Mike6, I was looking to get the tires into the wheel wells. Now the lip of the fender is about 8 inches higher(extremely high. I just bought the truck last year and i am in the process of re-wiring, a new dash and gauge setup as well as replacement of an add on power booster and single jam jar master that is leaking. I haven't really driven as yet other than off the trailer, but just looking at it, it must be a very harsh ride.
I used a 4 inch drop axle in front with single leaf springs. Front end is at a good height. Rear end has single leafs also, with reversed eyes. A definite improvement, but still not ideal. One day I will look at putting the rear axle over the springs instead of under, and that should work.
There are some pretty good pics in my gallery of the front suspension.
Wow...you have 8 inches between the top of the tire and the bottom of the fender? I assume the front?
That;s way, way higher than it ever came from Ford.
Maybe someone replaced those springs with something else?
I have a set of F1 springs(off a '48, but sure they are the same) I can measure the unloaded heighth so you can try to get an idea of what you're working with...give me until late tomorrow morning, I need to make a dump run, then pick up some drywall from HD..be ;ate morning before I get back home.
Thanks for the great info. I checked out your gallery 46yblock and that stance looks great. Did you make the upper front shock brackets or where they from a later model?
3mike6 i will see if I can create a gallery and post a few picts to show how high fender is over 235 x 15 tire. I believe there are about 10 leafs at least and they even have a small coil inserted in the centre of the leaf setup I assume to compensate for old leaver shocks.
I can't figure out how to add picture, i don't think I have rights or something. There is some pictures in the link called picture gallery on my site Home Page
that shows the height.
Thanks. The upper shock mounts on the front are stainless from Speedway. Bolt on, but with close tolerance shoulder bolts they arent every going anywhere.
As for stance. It looks awsome from a dead on front view, either standing still or coming at you down the highway. The rear fenders show above the fronts and it is cool. However, from a side view fenders are still too high off the wheels for my likiing. Oh well.
Rear shocks are mounted onto a welded in cross member. If you do a crossmember for shock mount, think also about possible location for underbed fuel tank. I didnt.
Guys regularly take everyother leaf out to improve ride. For rears minimum would be 4 springs retained.
46yblock,
that's great info. I was looking at moving the tank from under front seat to between rear frame rails using a mustang tank and square tubing to mount it in. I will watch out for positioning to ensure shock bar can be mounted between rails.
John
I checked the F-1 springs I have, from center of each eye to the top of the spring pack, is about 4.5 inches.., I don't think it'd chnage more than 1/2 inch to an inch with an engine and sheetmetal on top.
To get a close idea of what your ride height will be without having to install the engine etc for weight is to install the transverse spring with ONLY the main leaf of the spring. Thats the method Pete and Jakes and Chassis Engineering suggest.
You have to remember he doesn't have a traverse spring...he has parallel leafs...
That said, when I put (before I too it out) the 5.0/AOD down on my '36 with a traverse spring front end, it only dropped it maybe 1/2 inch...this with the original '36 springs.
I think (IMO) he needs to invesigate why the front end is so high, then make a game plan
An axle and spring business can reduce the arc in springs. Most of them also have data going back to 1946 and maybe earlier, so could check the arc and eye to eye measurement to make sure the spings are to specification.
Personally I would look for other alternatives. For example, when I was first putting together the '46 I had new rear springs made. Took out all but 6 leaves. It's ride was bad on kidneys and rear was way up there. Still have the new springs with 10 miles on them if anyone needs em.
I have a 1947 that I have lowered I can send you a picture and if you like the stance I can tell you exactly how i did it. However if your using the stock springs and lowering as much as I did you are going to have to accept very limited travel about 2 inches which is fine on a smooth road but hell on a bumpy road. There is a picture of the truck on the msn user groups 42-47 trucks under daniels drag truck paint was not complete at this time but thats is how the truck sits.
