04 Expedition 2wd averaging 13 mpg's between city/highway
Old Jun 10, 2008 | 11:21 AM
levnubhin's Avatar
levnubhin
I know this has been talked about endlessly but im a little concerned. My 04 only has a shade over 32K. In city driving i have seen the computer dip down to low 12's and on highway the best I have seen is 13.3 I just checked my tire pressure and its 38 cold all around. What could be wrong? I would imagine nothing at 32K but the mileage seems really low compared to what I have seen other people complain about.
Thanks!
Old Jun 10, 2008 | 11:30 AM
kaboom10's Avatar
kaboom10
I get those kind of mpg's in town but I went to a 4.56 gear ratio. I'd clean the MAF with a cleaner formulated for it like CRC MAF cleaner. Don't touch it just access it and spray it off a few times.
Old Jun 10, 2008 | 12:10 PM
sbclemens's Avatar
sbclemens
Your on board computer is not that reliable for giving you accurate mpg data. Also, it seems you're running your tire pressure a little low.
Old Jun 10, 2008 | 12:24 PM
levnubhin's Avatar
levnubhin
Really? What do you suggest? The sticker on the door jamb says 35psi cold for front and rear.
Old Jun 10, 2008 | 12:47 PM
sbclemens's Avatar
sbclemens
I run 40 psi in mine. Others may even go higher.
Old Jun 10, 2008 | 01:17 PM
alloro's Avatar
alloro
It is not a good idea to run your tire pressure at anything other than what the manufacturer suggests. Not only do you have less rubber on the road for safe traction, you will prematurely wear out your tires, offsetting any fuel savings.
Old Jun 10, 2008 | 01:32 PM
sbclemens's Avatar
sbclemens
The tire pressure stated on the door is for the tires supplied with the vehicle. The tire pressure listed on the tire may or may not be higher. I can safely run mine up to 45 psi.
Old Jun 10, 2008 | 02:08 PM
Trailblazen's Avatar
Trailblazen
He has a point, the door figures are for the stock conti tires supplied with the truck.
Nikolai
Aug 28, 2007 10:24 PM
darthcasp
1983 - 2012 Ranger & B-Series
89
Jan 16, 2007 02:58 PM
champ7718
2004 - 2008 F150
Apr 27, 2006 06:42 PM
knmhoffman
Feb 24, 2005 11:14 AM
alfama351
Nov 9, 2004 07:26 PM
