Sponsored by: Auxito
Grinding type noise from
Old May 30, 2008 | 09:53 PM
wresleu's Avatar
wresleu
the compressor/condensor. Not only does it do it when the a/c is on, but also when the heat is on any of the settings other than floor. So I'm assuming it must be a bearing or something in the compressor? Is it possible for a DIY'er to replace the bearing in one of these, or is this a job better left to a pro? I'm not afraid of getting dirty, but I don't have a single a/c related tool in my possession. I'd imagine that the hoses require a special tool to be removed? Anyone else had this similar problem...if so what did it turn out to be? The truck still has a/c and everything, but it really sounds bad when it's on.
Old Jun 2, 2008 | 02:31 PM
Eatonpcat's Avatar
Eatonpcat
Same problem here, Originally thought about bypassing the compressor with a belt from a truck w/o AC.. But found out it wasn't that easy.. My truck sounded like a jet engine.. Didn't want to take the chance and just change the bearing. For me the hardest thing was rerouting the belt.
Old Jun 3, 2008 | 07:45 AM
mjunk1's Avatar
mjunk1
I haven't done a lot with AC but I would be inclined to take it to someone. Those systems are under a lot of pressure on the high side and I always worry that I might do something and catch an eye full of R134 or something worse. I believe there are special tools to be able to drain the pressure off safely and then changing the bearing would be possible.
I don't shy away from too much on my truck, but the AC system is one of them.
Old Jun 3, 2008 | 09:21 AM
Eatonpcat's Avatar
Eatonpcat
Don't be afraid of a little 134 to the snout.... It tastes like chicken
Old Jun 3, 2008 | 12:11 PM
Club Wagon's Avatar
Club Wagon
While almost any DIY repair is "possible" this 1 is not usually recommended. Mostly rebuilt compressors are installed by "a pro". When I had an AC clutch idler bearing go nobody even stocked these external compressor parts! If your "noise" hasn't gone on long there is a slim chance you could revive it for awhile by adding a refrigerant oil charge.
The AC hoses attach to the compressor via a manifold that comes off w/an ordinary wrench. The most valuable "special tool" in your case is a refrigerant recovery system. These costly shop tools recycle the R134 & vacuum dry the opened system in preparation to recharge it. While the "DIY'er" can R&R a compressor, few are equipped to save the R134 or evacuate the system.
After relentless antienvironmentalist bashing for mentioning "legal bull*****" I hesitate to recommend against the wasteful practice of dumping R135 that many 'shade tree' mechanics use. However dealing w/R134 is a major hurtle in replacing a compressor bearing or whole compressor.
Old Jun 3, 2008 | 12:42 PM
Eatonpcat's Avatar
Eatonpcat
Just call me Mr. Shadetree.... I believe doing it myself cost around $300.00 (including new belt & recharging system), I can't imagine what a shop would charge. Sometimes the enviroment has to take a hit.
Old Jun 4, 2008 | 01:53 AM
Club Wagon's Avatar
Club Wagon
Venting R134 into the atmosphere & recharging are one thing. How do you evacuate the system after reassembling it to prepare it to be recharged?
Leaving air & moisture inside the system may well lead your repair "to take a hit" prematurely. I've got a vacuum pump, an AC gauge manifold & an old friend w/refrigerant recycler.
Perhaps I did not make it clear that many a "DIYer" can R&R the compressor, leaving just the recharge to a pro, for someone w/o any AC tools.
Its also unclear if your "Mr. Shadetree" referred to replacing the compressor's bearing, which can require "special tools" or just swapping out the compressor.
Old Jun 4, 2008 | 02:19 AM
LxMan1's Avatar
LxMan1
I would replace the compressor. But it needs to be vacuumed down and properly done as in also replacing the receiver/dryer and orfice tube.
Old Jun 4, 2008 | 05:56 AM
Eatonpcat's Avatar
Eatonpcat
I replaced the compressor then took it to be recharged at a mechanic.
