Sponsored by: Auxito
Ball Joints, tie rods, etc.
Old May 29, 2008 | 11:03 AM
golfgooroo's Avatar
golfgooroo
I'm replacing the Upper and Lower ball joints on my 2000 F-150 2WD tomorrow which should be no problem with RACERGUYs go-by. But I'd like to know if it wise to spend the $150 to replace the inner and outer tie rods as well. Or if there is a way to inspect them, that would help out too. Appreciate any help!
Old May 29, 2008 | 12:23 PM
camden2300's Avatar
camden2300
I went ahead and did my outers at the same time but not my inners. Just make sure to install the camber kit when you do it. I told the guy Guy at orielys that i wanted it and he argued with me and talked me out of getting it....I took it to get aligned yesterday and they first thing they said was it needs a camber kit and they wanted 110 to install it...so i bought it for 45 and did it myself.
Old Jun 2, 2008 | 12:39 PM
golfgooroo's Avatar
golfgooroo
Ball joint replacement was pretty easy except that the ball press only got the lower ball joints out. It was too small to get them back in....I used a floorjack. I did go ahead and replace upper and lower tie rods while I was under there. The alignment was way off when I was done but I bought the camber kit and took it to my alignment shop. I had previously paid the extra $20 for a "lifetime" alignment so that was a well $20 spent.
Old Jun 3, 2008 | 07:09 AM
golfgooroo's Avatar
golfgooroo
I couldn't tell what exactly the camber kit is used for. I didn't see any adjustments other than the two large washers that came with it. Am I missing something? From the factory, there are two bushings on either side of the upper arm mounting bolts.
VQT
Apr 4, 2013 10:21 PM
mykdee
Dec 23, 2011 05:29 AM
FordTrucksKickGM
1997 - 2003 F150
Nov 17, 2009 10:15 AM
forddd
1997 - 2003 F150
Aug 10, 2006 10:22 PM
nordford56
Mar 5, 2002 07:25 PM
