1994 f150 5.0 idles eratically
My dad has a 1994 f150 with the 5.0 v8. Whenever you crank it the rpms and the idle fluctuate up and down. It is a real pain when you are trying to get out of a parking spot b/c turning the wheels sharply makes it worse and it usually cuts off.
It will even do it while in park.
I was told that this is a fairly common issue. Any advice would be greatly appreciated.
bad idle
I had an idle problem too.....when I let off the gas the motor would drop down to 500 rpms and sometimes die......if I have the A/C on and let off the gas the motor drops way down and almost dies everytime....if I have the A/C on and let off the gas while turning, the motor dies everytime.....I researched it for several days and even posted it on this website under "BAD IDLE" and I was told it was a bad Idle Air Control Valve...aka IACV or IAC.
I bought a new one yesterday and I will put it on (looks easy) this Saturday then post the results....look into it and give it a try. The part cost about $75 at Advance Auto.
1992 F150 Supercab 173,000 miles 302 V8 automatic 2WD XLT
Fixed it.
I took the IAC off and spayed WD-40 in it since I couldn't find my card spray. I took a small flat head and scraped the carbon that was built up and then sprayed some more. Reinstalled the IAC and no problems!
