Offroad & 4x4
78 f250 wheel offset-Dana 60
Old Apr 14, 2008 | 02:18 AM
dirtyoffroad's Avatar
dirtyoffroad
I got no reply on the tire and suspension forum.I've got 35-12.5-16.5 tires right now,I'd like to go with something around 40 inches now since the 8 inch lift.I was always under the impression that a 16.5 wheel didnt hold a bead well at low pressure so I might have to get new wheels too.What sort of wheel sizes and offset specs do I need to keep the tires from hitting my fenderwell and headers
Old Apr 14, 2008 | 05:35 AM
fishmanndotcom's Avatar
fishmanndotcom
16.5's dont hold a bead under about 15, start gettign worried. last year at GrayRock, my first obstacle waiting in line i lost a bead on mine. they were all about 8psi so i was lucky i made it that far. it all depends on how low you want to go and what you will be doing. if just mud then 16.5's will be fine.
i would say the standard offset that most have good luck with is 3.5-4.5.
-cutts-
Old Apr 14, 2008 | 09:54 AM
captain p4's Avatar
captain p4
I ran my 16.5s at 15 all day at rc with no problem, but I didn't try going under that. My backspacing is 4.75 and I don't have any problems (on a bronco with radius arms though). This is on 36x12.5x16.5 tires.
Old Apr 14, 2008 | 06:51 PM
dirtyoffroad
I air my jeep tires into the single #s and it makes such a big difference in traction and smooth ride,less likely to spill beer.Am wondering if I should look for something in 17" size.PS I had the front driveshaft yoke off Saturday when I moved the truck to drier ground to work on it,hubs were locked,pulled pinion shaft into diff case,broken teeth and bits of steel nowguess I can go with those 4.88s now
Old Apr 14, 2008 | 06:58 PM
STGFordCrazy04's Avatar
STGFordCrazy04
the gears are a great idea but I have to ask are you running a D44hd or D60 front? Id bet most anything that because of recent carnage its a D44. 40s will only make it worse.
Personally I wouldnt waste any more money on the D44 when you know you want 40s in the near future.
Old Apr 14, 2008 | 07:03 PM
dirtyoffroad
its a 60,I've already contacted Complete Offroad for a quote on new gears and install kits,any other vendors I should try?
Old Apr 14, 2008 | 07:06 PM
STGFordCrazy04
Ok good.
I wouldnt contact anyone else unless you want to spend more money. Fishy told me about Mike at COR and I have been very satisfied with price, quality, ease of delivery and customer service.
I dont recommend anyone else.
Old Apr 14, 2008 | 07:43 PM
fishmanndotcom
cant give that place anymore kudos or i would! mike kicks **** and he's a very down to earth guy!
you destroyed a 60's R&P?? ouch! i know that sucks! how did the pinion shaft end up falling in? i am guessing you didnt put it back together for the short trip to drier ground!?!? OUCH!
my tires stay at 5-7psi and that is about perfect! too much more air and i lose traction, any less and my steering feels all haywire (more so than normal!)
-cutts-
Old Apr 15, 2008 | 02:09 AM
dirtyoffroad
The pinion yoke was off,I had new yokes to put on for my High Angle CV shaft.The hubs were locked,so when I moved forward it rotated all the internals pulling the angled pinion gear into the diff.Its ugly in there,I thought I was just stuck in the mud so I went back and forth a few times before I unlocked the hubs,so 4.88 gears and ARBs
Old Apr 20, 2008 | 12:13 PM
dirtyoffroad
Got a set of 42" swampers on Trailready beadlock wheels,truck looks sweet,still waiting for my axle parts though
Old Apr 22, 2008 | 11:32 AM
scottfreeman's Avatar
scottfreeman
I don't think that should be an issue........
My brother almost died because he was drinking and 4wheeling.........
Old Apr 22, 2008 | 01:03 PM
chrono4's Avatar
chrono4
got any pics of the new bling? Most everyone I know drinks when they wheel privte land. Doesn't make it right, but it happens.
Old Apr 22, 2008 | 02:15 PM
dirtyoffroad
Andrew,I'll see if I can add a few photos to my gallery
Old Apr 22, 2008 | 06:16 PM
scottfreeman
Drinking
It is not a very smart practice. Good way to hurt somebody.
Old Apr 22, 2008 | 07:00 PM
STGFordCrazy04
Im not saying youre wrong but this is not the place for an ethics debate.
