OIL leak!!!
I was under the truck last night and noticed it was wet with oil, bottom of the pan, and drivers side of the block. Looked closer this morning and it looks like it is coming from the glow plug area? Running down right by the motor mount. Number 4 cylinder looks the wettest. The one closest to the cab. Is this common for plugs to leak? The passengers side is dry. Is there a seal/o-ring on the plugs could it have been a poor install?
<table class="MsoNormalTable" style="width: 387pt; border-collapse: collapse;" border="0" cellpadding="0" cellspacing="0" width="516"> <tbody><tr style="height: 13.55pt;"> <td style="border-style: none none solid; border-color: -moz-use-text-color -moz-use-text-color windowtext; border-width: medium medium 1pt; padding: 0in; width: 387pt; height: 13.55pt;" width="516"> Most Common Places for Oil to Leak (use a dye to find actual leak point) <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> CAC Tubes = 21%
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> ICP Sensor = 16% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Glow Plug Harness = 14% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Cam/Crank Position Sensor =14% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Front Crankshaft Seal = 8% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Upper to lower block seal (skirt) = 5% (bedplate?) <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> http://dan.prxy.org/Truck/6L_bible_html/html/Page_022.html <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> HPOP cover = 4% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Oil Cooler (this leaks into engine coolant) = 4% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Front or Rear Engine Cover = 3% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Rear Crank Seal = 3% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Turbo Charger & VGT actuator = 2% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Covers (oil pan, valve covers, breather) = 2% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> Cracked or Porous Block or Head = 1% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> IPR valve/Engine Lube oil pump = <1% <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> <o></o>
</td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> https://www.ford-trucks.com/forums/622121-oil-leak.html <o></o> </td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> http://www.forddoctorsdts.com/photographs/index3.php </td> </tr> <tr style="height: 12.75pt;"> <td style="padding: 0in; width: 387pt; height: 12.75pt;" width="516"> http://intellidog.com/dieselmann/60bulletin.htm <o></o>
</td> </tr> </tbody></table>
<hr> Glow Plug <sup>
Printable View (215 KB)</sup> <table border="1" cellpadding="3" cellspacing="0" width="50%"> <caption>Material</caption><tbody><tr valign="top"> <th>Item</th> <th>Specification</th></tr> <tr valign="top"><td>SAE 15W-40 Super Duty Motor Oil
XO-15W40-QSD or equivalent</td><td align="center">WSS-M2C171-D</td></tr> <tr valign="top"><td>RTV Silicone Sealant
TA-31</td><td align="center">—</td></tr> </tbody></table> Removal
RH glow plugs
- NOTE: Use a six point socket squarely seated on the retaining nut for removal.
For automatic transmission equipped models, remove the retaining nut and position the transmission fluid indicator tube aside.- Discard the retaining nut.
- Remove the RH fender splash shield. For additional information, refer to Section 501-02.
- Trim the evaporator case to provide glow plug buss bar removal clearance.
- Measure and mark a line just below the bottom rib on the evaporator case, from the RH edge outboard toward the wheel, 10 mm (0.39 in) to 15 mm (0.59 in). From that point mark a line downward at a 45 degree angle toward the outboard side of the vehicle.
- Using a carbide burr bit and a 90 degree angle grinder, remove the corner.
- NOTE: RH shown, LH similar.
Disconnect the glow plug electrical connector.
- Remove the glow plug buss bar.
- NOTE: If coolant is found on the glow plug, a new glow plug sleeve may have to be installed. For additional information, refer to Glow Plug Sleeve in this section.
Remove the glow plug.
All glow plugs
- Install the glow plug.
- Clean and apply clean engine oil to the O-ring seals.
- Install the glow plug buss bar.
- Connect the glow plug electrical connector.
- Apply RTV silicone sealant to the edge of the evaporator case that was trimmed for glow plug buss bar removal.
- Install the RH splash shield. For additional information, refer to Section 501-02.
- Position back the transmission indicator tube and install a new M6 retaining nut.
Here's the online manual for the 06 Super Duty...
https://www.motorcraftservice.com/pubs/content/~WS6O/~MUS~LEN/20/S6OMAIN.HTM
Also in your email now...
