Codes i got today....How bad?
Old 03-24-2008, 07:02 PM
f350rebel's Avatar
f350rebel
f350rebel is offline
Question Codes i got today....How bad?
pulled these codes today
P0605
P0541
P0238
P1211
P0478
What are these codes and how bad are they?
Also my HPOP peaked at 3000 psi, but leveled off at 1900 psi is it bad or is this normal
Old 03-24-2008, 07:03 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
Is your truck running ok?
Old 03-24-2008, 07:11 PM
Benny2002's Avatar
Benny2002
Benny2002 is offline
Can you clear them with what you pulled them with, then see what comes back and youll know more
Old 03-24-2008, 07:12 PM
zx250's Avatar
zx250
zx250 is offline
P0605 Internal Control Module ROM Error
PO541 Manifold Intake Air Heater
P0238 Turbo Boost Sensor A Circuit High Input
P0478 Exhaust Pressure Control Valve High Input
P1211 ICP Not Controllable - Pressure Abow/Below Desired
Clear them, run it and see what comes back. The first two usually don't amount to much. the 478 usually means you EBPV sensor tube needs cleaning. The 1211 could mean anything from a bad ICP to dirty oil.
Old 03-24-2008, 07:17 PM
F350-6's Avatar
F350-6
F350-6 is offline
I don't know why I bother looking these codes up when Barry can usually post 2 or 3 replies before I get around to one.
These codes tell me you have a chip/tuner asking your engine components to perform outside their normal parameters, which of course is the whole point of a chip.
I'm not sure about the 0541 being part of the tuner, but one of the guys here or Jody could tell you for sure.
Old 03-24-2008, 07:19 PM
totin_tools's Avatar
totin_tools
totin_tools is offline
Just replied to the other post.
Old 03-24-2008, 07:55 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
1211 is from the chip. If on stock, your ICP stays up around 2800-3000 then you are OK. In a high tune it will drop off on stock split shots as they use the available oil. 0541, I don't think this has anything to do with the chip. I get it all the time as my IAH is in the shed somewhere.
Old 03-24-2008, 08:23 PM
f350rebel's Avatar
f350rebel
The truck seems to be running fine when i had it running on 80econ just cruising i was at 3000 but when i put it on 140 and ran her hard she leveled at 1900..... My fuel economy is a bit low waiting for warmer weather to clean it or just delete it all together i think that will take care of the EBP code...... When i did the intake i put the plug back into the K&N...... Not sure why the map sensor one is like that or the 605 PCM code any ideas....It was the scanner that the dealership uses we buzz tested the injectors and i also have a glow plug code didnt list that one (i dont think)
