I have a '96 250 HD, and in the last year have done ball joints, axle shafts, u-joints, hubs, and just now all tie rods. I put the tie rods on measured to the old ones and I am REALLY toed out. I have new adjusters on so the aligment shouldn't be bad. I was wondering if anyone knew what the specs were before I went and did this, as most aligment shops around me will charge as if it is 550, and to "set the toe and let it go" seems a bit exspensive. Thanx
J
You will want to post your question in the tech forums since this one is used for intros. Try posting here: https://www.ford-trucks.com/forums/forum28/ There is also a forum for steering that may be of help and you can get to it by clicking on the Forums tab at the upper left.
Hi and welcome.
Go into your User CP, this tab is in the upper left hand corner of all FTE pages and you`ll see where to edit your signature under ''Settings & Options''.
Be sure to fill in the location field in ''Edit Profile''.
