'96 front end specs
Old Mar 22, 2008 | 11:04 AM
HDCrab's Avatar
HDCrab
'96 front end specs
I have a '96 250 HD, and in the last year have done ball joints, axle shafts, u-joints, hubs, and just now all tie rods. I put the tie rods on measured to the old ones and I am REALLY toed out. I have new adjusters on so the aligment shouldn't be bad. I was wondering if anyone knew what the specs were before I went and did this, as most aligment shops around me will charge as if it is 550, and to "set the toe and let it go" seems a bit exspensive. Thanx
J
Old Mar 22, 2008 | 11:54 AM
Ultramagdan's Avatar
Ultramagdan
Hello!
You will want to post your question in the tech forums since this one is used for intros. Try posting here: https://www.ford-trucks.com/forums/forum28/ There is also a forum for steering that may be of help and you can get to it by clicking on the Forums tab at the upper left.
Good luck!
Old Mar 22, 2008 | 08:39 PM
HDCrab's Avatar
HDCrab
Thanx much
J
Old Mar 23, 2008 | 05:55 AM
HDCrab's Avatar
HDCrab
How do you get your "signature" on here with your name and vehicle?
Old Mar 23, 2008 | 05:42 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome.
Go into your User CP, this tab is in the upper left hand corner of all FTE pages and you`ll see where to edit your signature under ''Settings & Options''.
Be sure to fill in the location field in ''Edit Profile''.
raprap1rp
New Member Introductions
Aug 22, 2007 04:59 PM
390NEWBORN
Aug 14, 2007 08:03 AM
mjb41847
Mar 20, 2007 05:14 PM
gabbie8
Mar 16, 2007 09:55 PM
