Seems my 02' Expl. MPG has dropped some.It has 140k on it and used to get close to 400 miles on a tank, now I'm down to 320 miles on a tank.I did replace plugs at 100k and still have original wires, but I don't think the wires would have that kind of effect.Engine seems to run pretty well.Any ideas?Also, has anyone dropped their gas tank and replaced the sending unit, mine is messed up.I tried some Chevron injector cleaner which was recommended on this site.thanks
Is it difficult to replace the fuel filter?Do I need to get any special tools.I have a tool I used to do my Bronco fuel filter line removal.Whats the MAF?Mass Air Flow?Where is it?thanks
Do a search in the Tech section. I believe there are some pics of it. It's a sensor that is on the air duct from the filter housing just downstream from said filter. 2-prong connector IIRC.
Remove connector, remove MAF. You'll see 2 very small wire elements THAT YOU DO NOT EVER TOUCH. If they have any fuzz or goop on them, use real honest to god "MAF Sensor Cleaner" spray from a good auto parts store. Spray, allow to air dry, re-install carefully.
If you did find crap on the MAF, after you re-install it, disconnect the NEG battery wire for several hours to allow the computer data tables to clear. The computer will re-learn the engine conditions with the newly cleaned MAF.
Found the MAF, but seems it takes a special tool for the two screws that hold it on the air duct.Looks like a torx with some little nipple sticking up in the middle?
Correct.
You either:
1) get a "security torx" bit from AutoZone or
2) Use a Dremmel to make a slot in the head of the screws so that you can use a flat blade screwdriver.
I was at Advance Auot Parts before I read your post and found the MAF cleaner.They do not have the bit so I did not get the cleaner yet.Also, why can't the sensor be cleaned still attatched to the plenum?I pulled the plenum off while putting in a new filter and could see the little wires in there and they did look clean.No debris that I could see on them.thanks
You're going to get a much better view and cleaning if you take it off.
