08 f-350 6.4 with snowplow on is not getting the proper out side air temp reading, which is cauing the a/c to blow when heat is all the way up. It just seems that the snowplow is blocking the air flow causing the sensor to read the heat from the engine. Has anyone seen or heard about this?
Does the same thing with the winter cover on grille.
Just do your heater manually.
jr
Yep, I experienced the same thing running with a grille cover in PA last week. Locate the temp sender, and you have identified the problem. Go from there. My fix was to remove the grille cover when necessary. Yours could be a couple different choices.
I took a 4" hole saw and drilled a hole in the upper right corner of the plow then attached a piece of dryer vent tube to the hole and ran it over the the temp sensor!
