302 to 400
I'm not trying to be an idiot or anything, because I have never ran one... but there are lots of mixed emotions about the 400. From what I have read, some people hate them and some swear by them. Do you think its really not worth the swap? I dont want to buy a 302 if I have a good running 400, is there anything you can do to the 400 to make it decent?
to make the 400 run you have to put money into head work, get the compression bumped up and a cam swap.
the 302 will run better and pass better in stock form then a stock 400 would.
good luck with the swap. if you know anyone that has a stock 400 in there truck see if you can ride with them or even drive it.
on
Technically I did the opposite. I put a 302/AOD in place of a 400/C-6 and was a direct bolt in. Just I also changed bodies as I'm using the 78 chassis as the foundation for my 51 truck. The 400 was a good motor but it had seen better days (approx 180 000 kms) and wouldn't get you anywhere fast. The main reasons were EFI, overdrive and fuel economy which the 400 couldn't supply easily.
strictly in the name of money, go with the 400. keep everything for the 302. Eventually rebuild the 302 for future reinstall when the gas prices are too high. FWIW, I got 10 mpg out of my 79 Bronco 400/C6, and 18 mpg out of my 85 F150 302 EFI/AOD. Both at 55mph. The '85 can't pass anybody on the highway, either. It's really tired, and the 400 is retired, lol.
