How long do you warm up your truck for?
Old Feb 13, 2008 | 10:17 PM
rangerfan's Avatar
rangerfan
I have an '06 3.0 that runs 5W20 through it. I usually just get in it and go unless I have to scrape the windshield.
Am I doing any long term damage? My wife warms her Fusion (same type of oil) for atleast 10 minutes because she likes it nice and toasty. I say that is just wasting gas.
What do you think?
Old Feb 13, 2008 | 10:28 PM
herman391's Avatar
herman391
If its crazy cold I let it (03 3.0 5w20) sit for a minute or two because I find if I don't the tranny will slip real bad for the first shift. Otherwise unless I'm scraping the windsheild I just get in a go.
If your drive is short and the engine rarely gets to temp (like mine) overtime sludge could build up, but proper maintence should take of that. Or so I've been led to believe.
Old Feb 13, 2008 | 10:34 PM
bazzman1953's Avatar
bazzman1953
I let my old '94 idle for about 90sec before I go. Kinda cool where I live. My owner [wife] lets her car warm up far longer, as your's does.
Once you learn to give up all hope, since you're doomed, you will feel a lot better about the waste of gas and money.
Old Feb 13, 2008 | 10:52 PM
rangerfan's Avatar
rangerfan
She lets it warm up for 10 minutes to drive 3 freaking miles.
Old Feb 13, 2008 | 11:11 PM
bazzman1953
Mine only drives hers 1mi, so I rest my case.
Old Feb 13, 2008 | 11:20 PM
rellik74's Avatar
rellik74
I wait for windshield to defrost, mostly 4 min or so unless its 15 deg or lower, had some below zero and I let it run 8 to 10 min. It get warmer inside if i drive it that seting there.
Old Feb 14, 2008 | 12:12 AM
Bear River's Avatar
Bear River
Former ******
I wait less than a minute. Once the oil starts flowing, I'm good to go. I haven't noticed any ill effects, and I drive about 15 miles to work, so it gets plenty warm before I reach my destination.
Old Feb 14, 2008 | 01:55 AM
CougarXR02's Avatar
CougarXR02
I usually let it run until it comes off the "high" cold idle (a couple mins) at least. I also will then drive out of OD until I either get to a cruising speed over 45, or i the temp needle starts to come to life. As mentioned before it likes to slip shifts when cold. Where My work is, I actually put it in second til I get out to the main drag to prevent any shifting as the trans comes up to temp, just roll out the side streets around 2000 rpms.
And the amount of gas used to idle a car for 10 minutes once a day is so small, is it really worth it? Is there a NEED? no, not really. But it doesn't hurt, and seems to help judging by sound and feel.
Old Feb 14, 2008 | 05:04 AM
wendell borror's Avatar
wendell borror
If my windsheild needs defrosted I warm it up to do that, if not I hop in and go,
Old Feb 14, 2008 | 06:08 AM
Rockledge's Avatar
Rockledge
This is what I do with my Taurus.
Since my Ranger is always garaged, I don't wait more than a minute or so after a cold start before I'm on my way. The key for any cold engine is no high revs (or lugging it) until the engine warms up some. So I just take it easy for a little while at first.
Old Feb 14, 2008 | 06:45 AM
wendell borror
It's alot easier to do these days with efi. Back when we had carbs if you didn't let them warm up they would buck and jump, sputter. Even ended up going to a hand choke on some rigs because the auto chokes sucked. With efi, you turn the key and go and the engine acts fine.
Old Feb 14, 2008 | 08:21 AM
BSmitty's Avatar
BSmitty
Yup, I fight it with my lincoln all the time, auto chokes were a bad idea! I let the Ranger run for about 30 seconds, that lets the oil circulate enough, and gets the exhaust manifold warm to the touch, so when it starts to elevate EGT under load it won't crack it. Then I keep the rpms below 2000, and keep it above 1/2 throttle until the heat gauge gets up to temp. No ill effects yet.
Old Feb 14, 2008 | 08:53 AM
sfcwoodret's Avatar
sfcwoodret
Unless it's below 32F, I just start and go. The engine warms as it goes. If it's below freezing then I'll give it a couple of minutes before I take off. It's not so much for the engine but for the other parts and fluids to come up to peak performance.
Old Feb 14, 2008 | 11:48 AM
rangersvt04's Avatar
rangersvt04
jeez man. i let mine warm up 5min usualy when its cold. and ususaly hop in and go in the summer.
Old Feb 14, 2008 | 12:05 PM
nelstone74's Avatar
nelstone74
I'll give it at least 5 minutes before I go but even when I take off I don't mash the pedal thru the floor I take it easy on it for a couple of miles. I think the tranny has a harder time warming up than the motor.
