Coolant Leak from Timing Chain Cover
Old Feb 12, 2008 | 07:50 PM
azu's Avatar
azu
I had this pesky small leak for about 18 months now. Took truck in for inspection and they told me they noticed this leaking. The whole time I thought it was the lower water pump gasket. Damn, to replace that is sort of a big job. I'll just wait until that goes or the water pump before I play with it. I only lose about a pint every month (1.5K). Anyone had this problem?
3.0 V6 2WD
Old Feb 12, 2008 | 11:06 PM
Hank85713's Avatar
Hank85713
had a block leak once used the BArrs stop leak with the little beads in it. Was recommended by the machine/radiator shop. sold the car 10 years later never had any more problems. Might help you
Old Feb 13, 2008 | 02:32 PM
ford_4.0's Avatar
ford_4.0
I have the 4L but had this same problem. Luckily I was able to fix it without pulling the pan, and the job only took a couple hours. if you do it without pulling the pan you have to be sure you cleaned everything real well though.
Old Feb 13, 2008 | 02:48 PM
Pablo-UA's Avatar
Pablo-UA
Try to retorq. fuel pump first.
Old Feb 13, 2008 | 11:06 PM
bazzman1953's Avatar
bazzman1953
I suspect the waterpump itself is dying. Of course, to replace it you have most of the front already removed, might as well replace the t-stat, hoses, and any other potential problems you may have. You will already be doing the teardown to get to the timeing chain area. My wife put the new waterpump et-al back together in 2 hours, so the job isn't as bad as you may think.
And use Never-seize on all the bolts that you pull.
A digital camera documenting your dis-assembly can also be quite useful.
Old Feb 14, 2008 | 01:50 AM
oldgoat49's Avatar
oldgoat49
I will second the digital camera suggestion. Anymore it doesn't matter much what I do I will take a picture of it before I start so that just in case something doesn't go back together right I can look and see what went where. Figure that it is easier to take a picture I don't need than to try to figure out what went where.
Old Feb 14, 2008 | 02:48 AM
Pablo-UA's Avatar
Pablo-UA
Between bearing and seal there is a dot letting coolant leack out if seal is worn. it increases bearing life a bit and let you drive to workshop with leaking pump, Ignoring leaking may cause seized pump...
Pescs334
Jun 14, 2014 02:28 PM
fridgeddiesel
Apr 16, 2014 12:49 PM
cixelsyd
1997 - 2003 F150
Mar 16, 2012 11:17 AM
Mr. Sandman
Jan 13, 2012 06:13 PM
b4hntn
1978 - 1996 Big Bronco
Jun 21, 2008 05:51 PM
