Sponsored by: Auxito
auxiliary transmission cooler question
Old Jan 29, 2008 | 11:28 AM
paker's Avatar
paker
Mine didn't come with one. I cut the metallic oil return line and flared it a little bit and put a rubber hose over it. Is there a better way? Thanks.
Old Jan 29, 2008 | 04:29 PM
Ultramagdan's Avatar
Ultramagdan
Nice to have you here.
If it's not leaking I'd say it's good.
Old Jan 30, 2008 | 12:26 AM
reeseracing23's Avatar
reeseracing23
only other way is with compression fittings but the way you did it will work fine. cooler lines don't have a lot of pressure
Old Feb 1, 2008 | 09:53 AM
paker's Avatar
paker
It is actually leaking after 2 years. The bulged area cracked and hose clamps don't seem to put uniform pressure on the tubing. I can either repair the joint every 2 years or put a compression fitting. Thanks for the suggestion. I will see if I can find a right size fitting for the aluminum tubing.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
