97 f150 v10 swap
Old Nov 7, 2007 | 02:56 AM
biofund's Avatar
biofund
97 f150 v10 swap
My 97 f150 has a v8 that runs on two cylinders. I have a 99 ford van that has a v10 and it runs great but the back is totaled. I can handle the grease and wrenching, I just want to know if I'm going to be able to swap ecu's or will I wind up using a closed loop hot rod style harness to complete the swap. Any help?
Old Nov 7, 2007 | 07:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can use the van ECU, but only with the van harness. The F150 harness won't fit the V10.
Old Nov 7, 2007 | 08:57 AM
xtrford's Avatar
xtrford
There is another Ford truck forum which I won't mention on here but a fella did a V10 conversion on his F150. Pretty darn impressive the job he did, so if you put your mind to it as well as your wallet....anything can be done.
Old Nov 7, 2007 | 02:35 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Can you post or PM me the link please?
Old Nov 7, 2007 | 05:11 PM
xtrford's Avatar
xtrford
Sent you a PM ATC.
frustratedvanowner
New Member Introductions
Feb 14, 2017 01:29 PM
Gruetzmacher
Nov 21, 2006 11:58 PM
