ton and half exhaust manifolds
My old truck I just bought is missing one side and the other side looks rough. Most of the after market ones I have found on the internet say there is clearance issues on the big trucks.
Thanks
Case1950
I have a set of FH V8 exhaust manifolds, but unsure if they'd work for you or not, I'll get the casting numbers off of them and let you do some investigation.
I'm assuming you're talking about a Y-block? ( I suppose you're not....)
I'm gonna use the ones in shown in my gallery. You can buy them new from Mummert.
I also had mine ceramic coated but that'll cost you about $225 more.
If you try to use dual exhaust manifolds meant for a car you'll have a problem with the left side hitting the steering box.
The only other options are headers (if you still want dual exhaust) or the crossover pipe and a single exhaust.
Cheers,
Rick
Thanks for the replys
case1950
I found a original set of manifolds at a local swap meet and they work great. Even with the original manifolds it is close to the steering box.
Thanks guys,
Case1950
